Salta al contenuto principale
Kushlan Cement Mixer 600DDS 2014 Power Components Replacement
Cosa ti serve
  1. Kushlan Cement Mixer 600DDS 2014 Power Components Replacement, Remove the motor cover bolts: passo 1, immagine 1 di 1
    • Before you begin, ensure the power cord is unplugged and the power switch is in the OFF position.
    • Use a 13 mm socket to remove the two bolts securing the motor cover to the frame.
  2. Kushlan Cement Mixer 600DDS 2014 Power Components Replacement, Remove the motor cover: passo 2, immagine 1 di 1
    • Remove the motor cover.
  3. Kushlan Cement Mixer 600DDS 2014 Power Components Replacement, Remove the electrical panel: passo 3, immagine 1 di 1
    • Use a Phillips screwdriver to remove the four screws securing the electrical panel.
  4. Kushlan Cement Mixer 600DDS 2014 Power Components Replacement, Remove the electrical panel: passo 4, immagine 1 di 1
    • Remove the electrical panel.
  5. Kushlan Cement Mixer 600DDS 2014 Power Components Replacement, Remove the on/off switch: passo 5, immagine 1 di 3 Kushlan Cement Mixer 600DDS 2014 Power Components Replacement, Remove the on/off switch: passo 5, immagine 2 di 3 Kushlan Cement Mixer 600DDS 2014 Power Components Replacement, Remove the on/off switch: passo 5, immagine 3 di 3
    • Use a pair of needle-nose pliers to disconnect the four wires from the back of the on/off switch.
    • During reassembly, ensure the wires are connected back into their original locations and the on/off switch is not upside-down.
  6. Kushlan Cement Mixer 600DDS 2014 Power Components Replacement: passo 6, immagine 1 di 3 Kushlan Cement Mixer 600DDS 2014 Power Components Replacement: passo 6, immagine 2 di 3 Kushlan Cement Mixer 600DDS 2014 Power Components Replacement: passo 6, immagine 3 di 3
    • Use a flathead screwdriver to press the sides of the on/off switch through the opening in the electrical box.
  7. Kushlan Cement Mixer 600DDS 2014 Power Components Replacement: passo 7, immagine 1 di 1
    • Remove the on/off switch.
  8. Kushlan Cement Mixer 600DDS 2014 Power Components Replacement, Remove the power cord: passo 8, immagine 1 di 1
    • Use a Phillips screwdriver to remove the two screws securing the fastener behind the strain relief fitting.
  9. Kushlan Cement Mixer 600DDS 2014 Power Components Replacement: passo 9, immagine 1 di 2 Kushlan Cement Mixer 600DDS 2014 Power Components Replacement: passo 9, immagine 2 di 2
    • Remove the fastener.
  10. Kushlan Cement Mixer 600DDS 2014 Power Components Replacement: passo 10, immagine 1 di 1
    • Use a Phillips screwdriver to remove the screw securing the green ground wire to the bottom of the electrical box.
  11. Kushlan Cement Mixer 600DDS 2014 Power Components Replacement: passo 11, immagine 1 di 1
    • Use an adjustable wrench to remove the power cord's strain relief fitting cap.
  12. Kushlan Cement Mixer 600DDS 2014 Power Components Replacement: passo 12, immagine 1 di 2 Kushlan Cement Mixer 600DDS 2014 Power Components Replacement: passo 12, immagine 2 di 2
    • Slide the cap off of the strain relief fitting.
  13. Kushlan Cement Mixer 600DDS 2014 Power Components Replacement: passo 13, immagine 1 di 3 Kushlan Cement Mixer 600DDS 2014 Power Components Replacement: passo 13, immagine 2 di 3 Kushlan Cement Mixer 600DDS 2014 Power Components Replacement: passo 13, immagine 3 di 3
    • Feed the power cord and its black, white, and green wires out through the strain relief fitting.
    • Transfer the strain relief fitting cap onto the new power cord.
  14. Kushlan Cement Mixer 600DDS 2014 Power Components Replacement, Remove the capacitor: passo 14, immagine 1 di 1
    • Use a Phillips screwdriver to remove the screw securing the capacitor support.
  15. Kushlan Cement Mixer 600DDS 2014 Power Components Replacement: passo 15, immagine 1 di 1
    • Remove the capacitor support.
  16. Kushlan Cement Mixer 600DDS 2014 Power Components Replacement: passo 16, immagine 1 di 3 Kushlan Cement Mixer 600DDS 2014 Power Components Replacement: passo 16, immagine 2 di 3 Kushlan Cement Mixer 600DDS 2014 Power Components Replacement: passo 16, immagine 3 di 3
    • Use a pair of needle nose pliers to disconnect the red and black wires from the capacitor.
    • Remove the capacitor.
    • Use tape or a zip tie to differentiate this set of red and white wires from the other set of red and white wires running to the on/off switch to ensure proper reinstallation.
Conclusione
Altre 7 persone hanno completato questa guida.
Sam Omiotek
Membro da: 02/25/19
84.811 Reputazione
290 Guide realizzate
1Commento della guida
Very well presented. The photos were very sharp and clear. From looking at your photos it would apear that you can reverse the motor rotation by reversing the 2 capacitor leads. This would make empting the mixer eaiser in some situations. Do you agree?
Thank you,
Drew Watson
Drew Watson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 88
Tutti i Tempi: 3,386
