Salta al contenuto principale
Kurio Xtreme Motherboard Replacement
Cosa ti serve
  1. Kurio Xtreme Motherboard Replacement, Back Panel: passo 1, immagine 1 di 1
    • Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
  2. Kurio Xtreme Motherboard Replacement: passo 2, immagine 1 di 2 Kurio Xtreme Motherboard Replacement: passo 2, immagine 2 di 2
    • Unscrew the four 4 mm black screws using a Phillips #000 screw driver.
    • There are two screws on each side of the device (four total).
  3. Kurio Xtreme Motherboard Replacement: passo 3, immagine 1 di 3 Kurio Xtreme Motherboard Replacement: passo 3, immagine 2 di 3 Kurio Xtreme Motherboard Replacement: passo 3, immagine 3 di 3
    • Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
    • Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
    • Be sure not to break any of the plastic clamps along the edges of the device when removing the back cover.
    • Carefully lift the back panel off of the rest of the device.
  4. Kurio Xtreme Motherboard Replacement, Motherboard: passo 4, immagine 1 di 1
    • Unscrew the three 4 mm screws with a Phillips #000 screwdriver.
  5. Kurio Xtreme Motherboard Replacement: passo 5, immagine 1 di 2 Kurio Xtreme Motherboard Replacement: passo 5, immagine 2 di 2
    • Remove the orange data display ribbon wire above the battery by prying open the ZIF connector with the plastic opening tool.
  6. Kurio Xtreme Motherboard Replacement: passo 6, immagine 1 di 2 Kurio Xtreme Motherboard Replacement: passo 6, immagine 2 di 2
    • Remove the orange data display ribbon wire to the left of the battery by prying open the ZIF connector with the plastic opening tool.
  7. Kurio Xtreme Motherboard Replacement: passo 7, immagine 1 di 3 Kurio Xtreme Motherboard Replacement: passo 7, immagine 2 di 3 Kurio Xtreme Motherboard Replacement: passo 7, immagine 3 di 3
    • Remove the 7 wires connected to the motherboard by soldering the ends that connect them to the motherboard.
    • 2 pairs of red and black speaker wires (4 wires total)
    • 1 pair of red and black battery wires (2 wires total)
    • 1 gray ground wire
    • The soldering iron gets very hot and may injure you if exposed to your skin.
  8. Kurio Xtreme Motherboard Replacement: passo 8, immagine 1 di 1
    • Remove the motherboard by lifting it out of the casing.
Conclusione
Mallory Myers
Membro da: 09/22/15
1.190 Reputazione
7 Guide realizzate
Baylor, Team 6-10, Williams Fall 2015 Membro di Baylor, Team 6-10, Williams Fall 2015
BU-WILLIAMS-F15S6G10
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 12
Tutti i Tempi: 929
