Salta al contenuto principale
Kurio Xtreme Battery Replacement
Cosa ti serve
  1. Kurio Xtreme Battery Replacement, Back Panel: passo 1, immagine 1 di 1
    • Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
  2. Kurio Xtreme Battery Replacement: passo 2, immagine 1 di 2 Kurio Xtreme Battery Replacement: passo 2, immagine 2 di 2
    • Unscrew the four 4 mm black screws using a Phillips #000 screw driver.
    • There are two screws on each side of the device (four total).
  3. Kurio Xtreme Battery Replacement: passo 3, immagine 1 di 3 Kurio Xtreme Battery Replacement: passo 3, immagine 2 di 3 Kurio Xtreme Battery Replacement: passo 3, immagine 3 di 3
    • Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
    • Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
    • Be sure not to break any of the plastic clamps along the edges of the device when removing the back cover.
    • Carefully lift the back panel off of the rest of the device.
  4. Kurio Xtreme Battery Replacement, Battery: passo 4, immagine 1 di 2 Kurio Xtreme Battery Replacement, Battery: passo 4, immagine 2 di 2
    • Disconnect the black and red wires from the motherboard by soldering the ends that are connected to the motherboard.
    • The soldering iron gets very hot and may injure you if exposed to your skin.
  5. Kurio Xtreme Battery Replacement: passo 5, immagine 1 di 2 Kurio Xtreme Battery Replacement: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Plastic Cards
    $2.99
    Compra
    • Slide iFixit's Plastic Card tool or a credit card under the battery to remove the glue that is holding it in place.
    • Be patient and gentle. The glue is strong and may take up to 30 seconds to remove.
    • Carefully lift the battery out of the device.
Conclusione
Altre 2 persone hanno completato questa guida.
Mallory Myers
Membro da: 09/22/15
1.190 Reputazione
7 Guide realizzate
Baylor, Team 6-10, Williams Fall 2015 Membro di Baylor, Team 6-10, Williams Fall 2015
BU-WILLIAMS-F15S6G10
3 Membri
14 Guide realizzate
2 Commenti
j ai changé de batterie mais la batterie ne charge pas. est ce que c ets parce qu un des deux fils serait mal soudé?
j-p1955 - Replica
Does it have a certain battery or can a different battery fit?
Nikki Gilliard - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 3,958
