Salta al contenuto principale
Kurio Motion MotherBoard Replacement
Cosa ti serve
  1. Kurio Motion MotherBoard Replacement, MotherBoard: passo 1, immagine 1 di 1
    • Use the Phillips #0 Screwdriver to remove four 5mm screws from sides of the device.
  2. Kurio Motion MotherBoard Replacement: passo 2, immagine 1 di 1
    • Use the Ifixit opening tool to pry open the device to remove the back of the Kurio Motion.
  3. Kurio Motion MotherBoard Replacement: passo 3, immagine 1 di 1
    • Remove the tape covering the tape from the edges of the battery.
  4. Kurio Motion MotherBoard Replacement: passo 4, immagine 1 di 1
    • Remove the orange connectors that are connected to the motherboard by lifting up the white tab, and then gently pulling the connector out.
  5. Kurio Motion MotherBoard Replacement: passo 5, immagine 1 di 1
    • Take out the 5mm screws located at the top right and left of the motherboard.
  6. Kurio Motion MotherBoard Replacement: passo 6, immagine 1 di 1
    • Remove the tape covering the camera gently.
  7. Kurio Motion MotherBoard Replacement: passo 7, immagine 1 di 1
    • Use your spudger to carefully take out the camera.
  8. Kurio Motion MotherBoard Replacement: passo 8, immagine 1 di 1
    • Use your soldering tool to solder the wires that are connected to the battery and the gray wire next them.
  9. Kurio Motion MotherBoard Replacement: passo 9, immagine 1 di 1
    • Use your soldering tool to solder the wires that are connected to the speakers.
Conclusione
Yazeed Ayyad
Membro da: 09/10/23
447 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 27
