Salta al contenuto principale
Kurio Motion Audio Jack Replacement
Cosa ti serve
  1. Kurio Motion Audio Jack Replacement, Audio Jack: passo 1, immagine 1 di 2 Kurio Motion Audio Jack Replacement, Audio Jack: passo 1, immagine 2 di 2
    • Use a Phillips #00 Screwdriver to unscrew the four 5mm screws.
  2. Kurio Motion Audio Jack Replacement: passo 2, immagine 1 di 1
    • Use an Ifixit opening tool to seperate the screen from the back.
    • The screen is connected to the back by tabs on the inside of the device. If you pry too hard, they may break.
  3. Kurio Motion Audio Jack Replacement: passo 3, immagine 1 di 1
    • Remove the tape from the edges of the battery and the small piece on the motherboard.
  4. Kurio Motion Audio Jack Replacement: passo 4, immagine 1 di 2 Kurio Motion Audio Jack Replacement: passo 4, immagine 2 di 2
    • Remove the two 5mm screws from the mother board.
    • Remove the connectors by lifting the tabs and pulling gently.
    • Desolder the connections holding the audio jack. To do so, refer to this guide.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 18
