Salta al contenuto principale
Kodak S100 EF Flash Capacitor Replacement
Cosa ti serve
  1. Kodak S100 EF Flash Capacitor Replacement, Back Cover: passo 1, immagine 1 di 2 Kodak S100 EF Flash Capacitor Replacement, Back Cover: passo 1, immagine 2 di 2
    • Remove the two 6.2mm Phillips screws on both sides of camera's back cover.
  2. Kodak S100 EF Flash Capacitor Replacement: passo 2, immagine 1 di 1
    • Turn camera so the bottom is facing up and the front is facing away.
    • Remove the two 6.2mm Phillips screws on the bottom back cover of the camera.
    • Back cover is now unscrewed an can be removed.
  3. Kodak S100 EF Flash Capacitor Replacement: passo 3, immagine 1 di 1
    • Have the back of the camera facing up.
    • Unscrew the 6.2mm Phillips screw next to the viewfinder.
    • The back cover is now unscrewed. Lift up and pull the cover off evenly.
  4. Kodak S100 EF Flash Capacitor Replacement, Flash Capacitor: passo 4, immagine 1 di 1
    • The capacitor is located at the bottom center of the camera.
  5. Kodak S100 EF Flash Capacitor Replacement: passo 5, immagine 1 di 1
Conclusione
Michelle
Membro da: 04/04/11
107 Reputazione
5 Guide realizzate
Cal Poly, Team 25-28, Garner Spring 2011 Membro di Cal Poly, Team 25-28, Garner Spring 2011
CPSU-GARNER-S11S25G28
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 2,351
