Introduzione
This guide demonstrates how to clean or replace the shutter button.
Cosa ti serve
Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
Before removing back cover, it is advisable to use an anti-static wrist strap to prevent damage to electronics.
Remove all 7 screws:
Hold the camera firmly with one hand so that you can still see a screw.
Place the Philips 00(Found here)screwdriver into the screw.
Turn the screwdriver to the left until it is free.
Repeat for the remaining screws.
Open the battery door.
Press thumb firmly on battery door and slide it in the direction of the arrow.
Lift thumb allowing the door to swing open.
The shutter button is held on to the front cover by three screws
Hold the shutter button in place
Use a Philips 00 screwdriver to remove the screws.
Hold down the shutter button portion of the selector dial
Press down the red tabs and slowly relieve pressure on the shutter button
Press down on the center red stick
Tool shown is Found here
