Salta al contenuto principale
Kodak Easyshare C813 Memory Card Replacement
  1. Kodak Easyshare C813 Memory Card Replacement, Memory Card: passo 1, immagine 1 di 1
    • Turn off camera by firmly pressing the power button that is located on the top of the camera near the mode selector dial.
  2. Kodak Easyshare C813 Memory Card Replacement: passo 2, immagine 1 di 3 Kodak Easyshare C813 Memory Card Replacement: passo 2, immagine 2 di 3 Kodak Easyshare C813 Memory Card Replacement: passo 2, immagine 3 di 3
    • Locate battery compartment on bottom of camera and slide open by applying pressure in the direction of the arrow.
  3. Kodak Easyshare C813 Memory Card Replacement: passo 3, immagine 1 di 2 Kodak Easyshare C813 Memory Card Replacement: passo 3, immagine 2 di 2
    • Locate memory card slot and insert memory card by inserting the gold terminals first.
    • Apply pressure into you feel it lock into place.
    • Note: To remove a memory card, apply pressure down until you feel it click. Then it should pop up and you can just pull it up.
  4. Kodak Easyshare C813 Memory Card Replacement: passo 4, immagine 1 di 2 Kodak Easyshare C813 Memory Card Replacement: passo 4, immagine 2 di 2
    • Return the battery door to its formerly closed position.
  5. Kodak Easyshare C813 Memory Card Replacement: passo 5, immagine 1 di 1
Conclusione
Cal Poly, Team 24-22, Regan Spring 2010 Membro di Cal Poly, Team 24-22, Regan Spring 2010
CPSU-REGAN-S10S24G22
4 Membri
20 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 100
Tutti i Tempi: 9,618
