Salta al contenuto principale
Kodak Easyshare C813 Logic Board Replacement
Cosa ti serve
  1. Kodak Easyshare C813 Logic Board Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
  2. Kodak Easyshare C813 Logic Board Replacement: passo 2, immagine 1 di 3 Kodak Easyshare C813 Logic Board Replacement: passo 2, immagine 2 di 3 Kodak Easyshare C813 Logic Board Replacement: passo 2, immagine 3 di 3
    • Press thumb firmly on battery door and slide it in the direction of the arrow.
    • Lift thumb allowing the door to swing open.
  3. Kodak Easyshare C813 Logic Board Replacement, Back Cover: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    Compra
  4. Kodak Easyshare C813 Logic Board Replacement: passo 4, immagine 1 di 1
    • Turn the camera off by firmly pressing the power button located on top of the camera.
  5. Kodak Easyshare C813 Logic Board Replacement: passo 5, immagine 1 di 3 Kodak Easyshare C813 Logic Board Replacement: passo 5, immagine 2 di 3 Kodak Easyshare C813 Logic Board Replacement: passo 5, immagine 3 di 3
    • Locate the 7 screws holding the back cover on.
    • Three screws are located on the bottom of the camera.
    • Two screws are located on the side shown in the photograph.
    • Two final screws are located on the opposite side shown in the photograph.
  6. Kodak Easyshare C813 Logic Board Replacement: passo 6, immagine 1 di 3 Kodak Easyshare C813 Logic Board Replacement: passo 6, immagine 2 di 3 Kodak Easyshare C813 Logic Board Replacement: passo 6, immagine 3 di 3
    Phillips #00 Screwdriver
    $5.49
    Compra
    • Remove all 7 screws:
    • Hold the camera firmly with one hand so that you can still see a screw.
    • Place the Philips 00(Found here)screwdriver into the screw.
    • Turn the screwdriver to the left until it is free.
    • Repeat for the remaining screws.
  7. Kodak Easyshare C813 Logic Board Replacement: passo 7, immagine 1 di 3 Kodak Easyshare C813 Logic Board Replacement: passo 7, immagine 2 di 3 Kodak Easyshare C813 Logic Board Replacement: passo 7, immagine 3 di 3
    • Use plastic opening tools to slightly open the side of the case.
    • Insert a plastic opening tool and apply pressure to the internal three tabs at the top.
    • The first two are near the words "3X Optical Zoom".
    • The third is near the shutter button.
  8. Kodak Easyshare C813 Logic Board Replacement: passo 8, immagine 1 di 3 Kodak Easyshare C813 Logic Board Replacement: passo 8, immagine 2 di 3 Kodak Easyshare C813 Logic Board Replacement: passo 8, immagine 3 di 3
    • Gently pull apart the back cover from the rest of the camera.
    • Make sure there are no more screws or tabs keeping the cover on.
    • Use the plastic opening tool to separate any sides still closely connected.
  9. Kodak Easyshare C813 Logic Board Replacement, Front Cover: passo 9, immagine 1 di 2 Kodak Easyshare C813 Logic Board Replacement, Front Cover: passo 9, immagine 2 di 2
    • Open the battery door.
  10. Kodak Easyshare C813 Logic Board Replacement: passo 10, immagine 1 di 3 Kodak Easyshare C813 Logic Board Replacement: passo 10, immagine 2 di 3 Kodak Easyshare C813 Logic Board Replacement: passo 10, immagine 3 di 3
    • Use the plastic opening tool to lift the casing around the shutter button.
    • Gently remove the front cover from the device.
  11. Kodak Easyshare C813 Logic Board Replacement: passo 11, immagine 1 di 1
    • Do not touch the terminals shown in the photo. These link to the capacitor which could shock you if not discharged.
    • To discharge the capacitor follow this guide.
  12. Kodak Easyshare C813 Logic Board Replacement, LCD: passo 12, immagine 1 di 3 Kodak Easyshare C813 Logic Board Replacement, LCD: passo 12, immagine 2 di 3 Kodak Easyshare C813 Logic Board Replacement, LCD: passo 12, immagine 3 di 3
    • Once the front cover is removed, the battery door maybe closed for convenience.
    • Locate the exposed portion of the LCD screen.
    • Use a wedge to free the LCD screen from the medal housing.
    • Do not pull the screen away completely, it is still attached to the logic board via the yellow cable.
  13. Kodak Easyshare C813 Logic Board Replacement: passo 13, immagine 1 di 1
    • Remove the screw at the upper right corner of the metal housing.
  14. Kodak Easyshare C813 Logic Board Replacement: passo 14, immagine 1 di 3 Kodak Easyshare C813 Logic Board Replacement: passo 14, immagine 2 di 3 Kodak Easyshare C813 Logic Board Replacement: passo 14, immagine 3 di 3
    • Locate the 2 solder joints holding down the medal housing.
    • Remove the solder.
    • Place wick on solder.
    • Place solder iron on wick
    • The wick should be sandwiched between the iron and the solder.
  15. Kodak Easyshare C813 Logic Board Replacement: passo 15, immagine 1 di 3 Kodak Easyshare C813 Logic Board Replacement: passo 15, immagine 2 di 3 Kodak Easyshare C813 Logic Board Replacement: passo 15, immagine 3 di 3
    • Peel back the black tape from the metal housing.
    • Lift the metal housing from the left so that it hinges on its right side.
    • The metal housing is still loosely attached on its right side.
  16. Kodak Easyshare C813 Logic Board Replacement: passo 16, immagine 1 di 3 Kodak Easyshare C813 Logic Board Replacement: passo 16, immagine 2 di 3 Kodak Easyshare C813 Logic Board Replacement: passo 16, immagine 3 di 3
    • Locate black tab holding the LCD screen connector in the port.
    • Use wedge or fingernail to lift the black tab.
    • Pull the the LCD screen connector out of the port.
  17. Kodak Easyshare C813 Logic Board Replacement, Logic Board: passo 17, immagine 1 di 1
    • Remove the medal housing from the logic board by carefully peeling the yellow tape off of the metal housing.
  18. Kodak Easyshare C813 Logic Board Replacement: passo 18, immagine 1 di 3 Kodak Easyshare C813 Logic Board Replacement: passo 18, immagine 2 di 3 Kodak Easyshare C813 Logic Board Replacement: passo 18, immagine 3 di 3
    • Locate the 2 screws on the yellow tape.
    • Remove the 2 screws.
    • Remove the yellow tape.
  19. Kodak Easyshare C813 Logic Board Replacement: passo 19, immagine 1 di 2 Kodak Easyshare C813 Logic Board Replacement: passo 19, immagine 2 di 2
    • Locate the 2 solder joints near the shutter button.
    • Remove the solder on both joints with the wick and soldering iron in the same manner as Step 11.
  20. Kodak Easyshare C813 Logic Board Replacement: passo 20, immagine 1 di 3 Kodak Easyshare C813 Logic Board Replacement: passo 20, immagine 2 di 3 Kodak Easyshare C813 Logic Board Replacement: passo 20, immagine 3 di 3
    • Turn the camera over.
    • Remove the screw holding the small green board.
    • Lift the small green board.
    • The small green board is still attached to the logic board via wires.
  21. Kodak Easyshare C813 Logic Board Replacement: passo 21, immagine 1 di 1
    • Desolder the remaining 20 solder joints connecting the logic board to the camera.
  22. Kodak Easyshare C813 Logic Board Replacement: passo 22, immagine 1 di 2 Kodak Easyshare C813 Logic Board Replacement: passo 22, immagine 2 di 2
    • Locate the black tab holding the yellow cable in place.
    • Use a plastic opening tool or fingernail to lift the black tab.
    • Pull the yellow cable from the port.
  23. Kodak Easyshare C813 Logic Board Replacement: passo 23, immagine 1 di 3 Kodak Easyshare C813 Logic Board Replacement: passo 23, immagine 2 di 3 Kodak Easyshare C813 Logic Board Replacement: passo 23, immagine 3 di 3
    • Use a plastic opening tool to lift the board from the camera.
    • Continue to remove the board completely.
Conclusione
Cal Poly, Team 24-22, Regan Spring 2010 Membro di Cal Poly, Team 24-22, Regan Spring 2010
CPSU-REGAN-S10S24G22
4 Membri
20 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 4,227
