Introduzione
This guide demonstrates how to install a LCD.
Cosa ti serve
Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
Attrezzo utilizzato in questo passaggio:Anti-Static Wrist Strap$7.95
Before removing back cover, it is advisable to use an anti-static wrist strap to prevent damage to electronics.
Remove all 7 screws:
Hold the camera firmly with one hand so that you can still see a screw.
Place the Philips 00(Found here)screwdriver into the screw.
Turn the screwdriver to the left until it is free.
Repeat for the remaining screws.
Use plastic opening tools to slightly open the side of the case.
Insert a plastic opening tool and apply pressure to the internal three tabs at the top.
The first two are near the words "3X Optical Zoom".
The third is near the shutter button.
Open the battery door.
Press thumb firmly on battery door and slide it in the direction of the arrow.
Lift thumb allowing the door to swing open.
Locate the exposed portion of the LCD screen.
Use a wedge to free the LCD screen from the medal housing.
Altre 2 persone hanno completato questa guida.
1Commento della guida
De sluiterknop werkt niet altijd, hoe is dit op te lossen?
