Introduzione
This guide demonstrates how to replace the door to the battery compartment.
Cosa ti serve
Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
Attrezzo utilizzato in questo passaggio:Anti-Static Wrist Strap$7.95
Before removing back cover, it is advisable to use an anti-static wrist strap to prevent damage to electronics.
Attrezzo utilizzato in questo passaggio:Phillips #00 Screwdriver$5.49
Remove all 7 screws:
Hold the camera firmly with one hand so that you can still see a screw.
Place the Philips 00(Found here)screwdriver into the screw.
Turn the screwdriver to the left until it is free.
Repeat for the remaining screws.
Open the battery door.
Press thumb firmly on battery door and slide it in the direction of the arrow.
Lift thumb allowing the door to swing open.
Attrezzo utilizzato in questo passaggio:Heavy-Duty Spudger$4.99
Use grey wedge(Found here) to push metal pin
Use tweezers(Found here)to pull out metal pin
Altre 4 persone hanno completato questa guida.
