Salta al contenuto principale
Kodak EasyShare M381 Lens/Optics Replacement
Cosa ti serve
  1. Kodak EasyShare M381 Lens/Optics Replacement, Battery: passo 1, immagine 1 di 2 Kodak EasyShare M381 Lens/Optics Replacement, Battery: passo 1, immagine 2 di 2
    • First, press in and slide forward the battery latch as indicated by the arrow.
  2. Kodak EasyShare M381 Lens/Optics Replacement: passo 2, immagine 1 di 1
    • Press down on battery until you hear a click and release it. Battery should easily slide out.
  3. Kodak EasyShare M381 Lens/Optics Replacement, Screen: passo 3, immagine 1 di 1
    • Remove the two 3.85 mm screws on the bottom right of the camera, as indicated.
  4. Kodak EasyShare M381 Lens/Optics Replacement: passo 4, immagine 1 di 1
    • Remove dial button located on top of camera, by gently pulling up.
  5. Kodak EasyShare M381 Lens/Optics Replacement: passo 5, immagine 1 di 2 Kodak EasyShare M381 Lens/Optics Replacement: passo 5, immagine 2 di 2
    • Starting at one side, carefully work the chrome frame off of the camera itself.
    • Be careful not to disturb the shutter or flash buttons on top of the camera.
  6. Kodak EasyShare M381 Lens/Optics Replacement: passo 6, immagine 1 di 1
    • On the right side of the camera, locate and remove the two 3.25 mm screws as highlighted.
  7. Kodak EasyShare M381 Lens/Optics Replacement: passo 7, immagine 1 di 3 Kodak EasyShare M381 Lens/Optics Replacement: passo 7, immagine 2 di 3 Kodak EasyShare M381 Lens/Optics Replacement: passo 7, immagine 3 di 3
    • Carefully lift the motherboard panel up, pulling towards the left. Make sure you do not rip the blue ribbon.
    • Using a plastic opening tool, gently lift up on the ribbon fastener until it is in an upright position.
    • Slide panel away from camera.
  8. Kodak EasyShare M381 Lens/Optics Replacement: passo 8, immagine 1 di 2 Kodak EasyShare M381 Lens/Optics Replacement: passo 8, immagine 2 di 2
    • Using a plastic opening tool, gently lift ribbon clamp as indicated to remove the screen ribbon from the motherboard.
    • Screen should now be detached. Gently lift it away from the base of the camera.
  9. Kodak EasyShare M381 Lens/Optics Replacement, Back Panel Frame: passo 9, immagine 1 di 3 Kodak EasyShare M381 Lens/Optics Replacement, Back Panel Frame: passo 9, immagine 2 di 3 Kodak EasyShare M381 Lens/Optics Replacement, Back Panel Frame: passo 9, immagine 3 di 3
    • Remove the 3.9 mm frame screws using a Phillips #00 screwdriver.
    • Using a magnetized surface to keep from losing screws may be very helpful.
  10. Kodak EasyShare M381 Lens/Optics Replacement: passo 10, immagine 1 di 2 Kodak EasyShare M381 Lens/Optics Replacement: passo 10, immagine 2 di 2
    • Using both hands, carefully pull the frame apart from the camera.
  11. Kodak EasyShare M381 Lens/Optics Replacement, Lens/Optics: passo 11, immagine 1 di 3 Kodak EasyShare M381 Lens/Optics Replacement, Lens/Optics: passo 11, immagine 2 di 3 Kodak EasyShare M381 Lens/Optics Replacement, Lens/Optics: passo 11, immagine 3 di 3
    • Locate and remove the four 3.25 mm screws securing the back panel to the frame of the camera using the Phillips #00 screwdriver.
    • Lift up and remove panel, detaching it from the camera frame.
  12. Kodak EasyShare M381 Lens/Optics Replacement: passo 12, immagine 1 di 2 Kodak EasyShare M381 Lens/Optics Replacement: passo 12, immagine 2 di 2
    • Remove the three 3.25 mm screws securing the hexagon-shaped, copper panel to the optical device.
    • Gently peel back the main optic ribbon, ensuring it is securely out of the way.
    • This ribbon is very fragile, and, if torn, the camera will not function properly. Handle with care.
  13. Kodak EasyShare M381 Lens/Optics Replacement: passo 13, immagine 1 di 1
    • Remove the six 3.25 mm screws securing the optic lens to the camera frame.
  14. Kodak EasyShare M381 Lens/Optics Replacement: passo 14, immagine 1 di 2 Kodak EasyShare M381 Lens/Optics Replacement: passo 14, immagine 2 di 2
    • Carefully remove the square lens film, ensuring you do not bend it. This film will be in two pieces: a black cover, and a glass square piece. It is very fragile, so handle with care.
    • This film is very fragile. Handle with care.
  15. Kodak EasyShare M381 Lens/Optics Replacement: passo 15, immagine 1 di 2 Kodak EasyShare M381 Lens/Optics Replacement: passo 15, immagine 2 di 2
    • There is a small ribbon attaching the optical lens piece to the motherboard. Using a plastic opening tool, gently lift up on this ribbon's clamp, detaching it from the motherboard.
  16. Kodak EasyShare M381 Lens/Optics Replacement: passo 16, immagine 1 di 3 Kodak EasyShare M381 Lens/Optics Replacement: passo 16, immagine 2 di 3 Kodak EasyShare M381 Lens/Optics Replacement: passo 16, immagine 3 di 3
    • The optic assembly should now be free. Use a pry tool to lift it far enough up that you can grab and remove it.
    • Be sure the detached ribbons are held out of the way to avoid any possible damage to them.
Conclusione
Un commento
I'm with ya up 'til step 2. The right hand back of my camera has controls (zoom in/out, trash/list/info, right/left/up/down, etc. on it and no visible screws as in your step 3 picture. It appears that another panel has been removed to expose these screws. Can you elaborate?
moe_r - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 27
Tutti i Tempi: 704
