Salta al contenuto principale
Kodak EasyShare M1033 LCD Screen Assembly Replacement
Cosa ti serve
  1. Kodak EasyShare M1033 LCD Screen Assembly Replacement, LCD Screen Assembly: passo 1, immagine 1 di 3 Kodak EasyShare M1033 LCD Screen Assembly Replacement, LCD Screen Assembly: passo 1, immagine 2 di 3 Kodak EasyShare M1033 LCD Screen Assembly Replacement, LCD Screen Assembly: passo 1, immagine 3 di 3
    • Ensure that the camera is powered off.
    • Turn the camera over so the battery compartment is facing up.
    • Place your thumb on the embossed surface of the battery latch, and push down and out until the latch releases.
    • Push down on the orange tab to release and remove the batteries.
    • Close the latch.
    • Let the camera sit for a minute to avoid electrical shock.
  2. Kodak EasyShare M1033 LCD Screen Assembly Replacement: passo 2, immagine 1 di 3 Kodak EasyShare M1033 LCD Screen Assembly Replacement: passo 2, immagine 2 di 3 Kodak EasyShare M1033 LCD Screen Assembly Replacement: passo 2, immagine 3 di 3
    • Use a Phillips #00 screwdriver to remove six screws along the edge of the camera.
    • There are two screws next to the battery compartment
    • Two screws on the left side
    • Two screws on the right side
  3. Kodak EasyShare M1033 LCD Screen Assembly Replacement: passo 3, immagine 1 di 3 Kodak EasyShare M1033 LCD Screen Assembly Replacement: passo 3, immagine 2 di 3 Kodak EasyShare M1033 LCD Screen Assembly Replacement: passo 3, immagine 3 di 3
    • Use a spudger or your fingernail to pry the plastic case covering the LCD screen from the back of the camera.
  4. Kodak EasyShare M1033 LCD Screen Assembly Replacement: passo 4, immagine 1 di 3 Kodak EasyShare M1033 LCD Screen Assembly Replacement: passo 4, immagine 2 di 3 Kodak EasyShare M1033 LCD Screen Assembly Replacement: passo 4, immagine 3 di 3
    • Use a spudger to gently pry the LCD assembly and move it to reveal a ZIF connector.
    • Don't pull it off as it is connected by a ribbon cable.
    • Use your fingernail or the tip of the spudger to flip up the small locking flap.
    • Gently pull the cable out.
    • Remove the old LCD screen assembly.
  5. Kodak EasyShare M1033 LCD Screen Assembly Replacement: passo 5, immagine 1 di 3 Kodak EasyShare M1033 LCD Screen Assembly Replacement: passo 5, immagine 2 di 3 Kodak EasyShare M1033 LCD Screen Assembly Replacement: passo 5, immagine 3 di 3
    • Carefully insert the ribbon cable of the new LCD screen assembly into the ZIF connector and securely flip the lock down.
    • Ensure that the ribbon is secure.
    • Place the LCD screen assembly back into the original position.
  6. Kodak EasyShare M1033 LCD Screen Assembly Replacement: passo 6, immagine 1 di 3 Kodak EasyShare M1033 LCD Screen Assembly Replacement: passo 6, immagine 2 di 3 Kodak EasyShare M1033 LCD Screen Assembly Replacement: passo 6, immagine 3 di 3
    • Place the back case on top of the new LCD screen.
    • Use the Phillips #00 screwdriver to replace the six screws along the edge of the camera that secure the back case.
    • Righty tighty.
Conclusione
ntuong1117
Membro da: 03/05/24
133 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 36
Tutti i Tempi: 515
