Salta al contenuto principale
Kodak EasyShare C913 LCD Screen Replacement
Cosa ti serve
  1. Kodak EasyShare C913 LCD Screen Replacement, Batteries: passo 1, immagine 1 di 3 Kodak EasyShare C913 LCD Screen Replacement, Batteries: passo 1, immagine 2 di 3 Kodak EasyShare C913 LCD Screen Replacement, Batteries: passo 1, immagine 3 di 3
    • Position the camera with the bottom facing up.
    • Slide the battery cover in the direction of the arrow with your finger gently.
    • Remove the batteries
  2. Kodak EasyShare C913 LCD Screen Replacement, Back Case: passo 2, immagine 1 di 3 Kodak EasyShare C913 LCD Screen Replacement, Back Case: passo 2, immagine 2 di 3 Kodak EasyShare C913 LCD Screen Replacement, Back Case: passo 2, immagine 3 di 3
    • Remove the seven 4.5mm screws with a Phillips #00 screwdriver.
    • 2 screws on the left
    • 2 screws on the right
    • 3 screws on the bottom
  3. Kodak EasyShare C913 LCD Screen Replacement: passo 3, immagine 1 di 3 Kodak EasyShare C913 LCD Screen Replacement: passo 3, immagine 2 di 3 Kodak EasyShare C913 LCD Screen Replacement: passo 3, immagine 3 di 3
    • Firmly grasp the back of the camera and pull the casing away.
  4. Kodak EasyShare C913 LCD Screen Replacement, Front Case: passo 4, immagine 1 di 3 Kodak EasyShare C913 LCD Screen Replacement, Front Case: passo 4, immagine 2 di 3 Kodak EasyShare C913 LCD Screen Replacement, Front Case: passo 4, immagine 3 di 3
    • Keep the battery door open
    • Firmly grasp the front casing and pull it away from the camera.
  5. Kodak EasyShare C913 LCD Screen Replacement, LCD Screen: passo 5, immagine 1 di 3 Kodak EasyShare C913 LCD Screen Replacement, LCD Screen: passo 5, immagine 2 di 3 Kodak EasyShare C913 LCD Screen Replacement, LCD Screen: passo 5, immagine 3 di 3
    • Look at the LCD casing and find the two smaller solder joints. One on either side of the camera secures the circuit board's casing. These are usually shiny and metallic points where the casing connects to the board.
    • Apply the tip of the heated smolder to the first joint to remove it. Contiune with the other side.
  6. Kodak EasyShare C913 LCD Screen Replacement: passo 6, immagine 1 di 3 Kodak EasyShare C913 LCD Screen Replacement: passo 6, immagine 2 di 3 Kodak EasyShare C913 LCD Screen Replacement: passo 6, immagine 3 di 3
    • Gently grasp the lower right side of LCD screen.
    • Lift the screen out of its casing.
    • Remove the 3 mm screw from the LCD casing using a #00 screwdriver.
  7. Kodak EasyShare C913 LCD Screen Replacement: passo 7, immagine 1 di 3 Kodak EasyShare C913 LCD Screen Replacement: passo 7, immagine 2 di 3 Kodak EasyShare C913 LCD Screen Replacement: passo 7, immagine 3 di 3
    • Gently grab the sides of the LCD casing and remove it from the camera.
  8. Kodak EasyShare C913 LCD Screen Replacement: passo 8, immagine 1 di 2 Kodak EasyShare C913 LCD Screen Replacement: passo 8, immagine 2 di 2
    • Lift the black tab gently with your finger.
    • Gently remove ribbon from underneath black tab.
Conclusione
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Cal Poly, Team 7-51, Amido Fall 2010 Membro di Cal Poly, Team 7-51, Amido Fall 2010
CPSU-AMIDO-F10S7G51
4 Membri
14 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 4,695
