Salta al contenuto principale
Kindle Fire HDX 7" Microphone Replacement
Cosa ti serve
  1. Kindle Fire HDX 7" Microphone Replacement, Speaker Bezel: passo 1, immagine 1 di 3 Kindle Fire HDX 7" Microphone Replacement, Speaker Bezel: passo 1, immagine 2 di 3 Kindle Fire HDX 7" Microphone Replacement, Speaker Bezel: passo 1, immagine 3 di 3
    • Insert an opening pick underneath the speaker bezel, and slide it along the perimeter to separate it from the tablet.
    • The adhesive is strong and may require an iOpener, or heat gun, to soften.
  2. Kindle Fire HDX 7" Microphone Replacement: passo 2, immagine 1 di 1
    • Remove the speaker bezel.
  3. Kindle Fire HDX 7" Microphone Replacement, Rear Panel: passo 3, immagine 1 di 1
    • Remove the six pink 3mm T3 Torx screws from the back case.
  4. Kindle Fire HDX 7" Microphone Replacement: passo 4, immagine 1 di 2 Kindle Fire HDX 7" Microphone Replacement: passo 4, immagine 2 di 2
    • Wedge opening picks around the perimeter between the display and back case.
    • Work the opening picks around the perimeter until the two halves disengage from each other.
    • Don't completely separate as the display ribbon cable still connects the two.
  5. Kindle Fire HDX 7" Microphone Replacement: passo 5, immagine 1 di 1
    • Use the flat end of a spudger to pry up and disconnect the rear panel press-fit connector from the motherboard.
    • There may be a glue strip between the battery and the outside case. Gently pry the case open and use the flat end of a spudger to separate the glue strip.
  6. Kindle Fire HDX 7" Microphone Replacement, Microphone: passo 7, immagine 1 di 2 Kindle Fire HDX 7" Microphone Replacement, Microphone: passo 7, immagine 2 di 2
    • Pry up the left speaker with the flat end of a spudger and remove.
  7. Kindle Fire HDX 7" Microphone Replacement: passo 8, immagine 1 di 2 Kindle Fire HDX 7" Microphone Replacement: passo 8, immagine 2 di 2
    • Pry up the right speaker with the flat end of a spudger and remove.
  8. Kindle Fire HDX 7" Microphone Replacement: passo 9, immagine 1 di 3 Kindle Fire HDX 7" Microphone Replacement: passo 9, immagine 2 di 3 Kindle Fire HDX 7" Microphone Replacement: passo 9, immagine 3 di 3
    • Pry up the microphone connector from the rear panel with the flat end of a spudger.
    • Pull up on the microphone with a pair of tweezers to remove.
Conclusione
Altre 2 persone hanno completato questa guida.
Blake Klein
Membro da: 01/29/17
70.583 Reputazione
50 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 14
Tutti i Tempi: 617
