Introduzione
If your Keurig is unable to turn on, you may need to replace your power cable with this guide.
Parti
Nessuna parte richiesta.
  1. Access the bottom of the Keurig by flipping it on its side. Access the bottom of the Keurig by flipping it on its side.
    • Access the bottom of the Keurig by flipping it on its side.
  2. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  3. Remove the five 13mm Phillips #0 screws securing the bottom case. Pull the silver cover off of the device. Pull the silver cover off of the device.
    • Remove the five 13mm Phillips #0 screws securing the bottom case.
    • Pull the silver cover off of the device.
  4. To remove the power cable, highlighted in red, follow iFixit's guide on soldering. The ground cable, highlighted in orange, needs to be re-soldered to your new power cable. The ground cable, highlighted in orange, needs to be re-soldered to your new power cable.
    • To remove the power cable, highlighted in red, follow iFixit's guide on soldering.
    • The ground cable, highlighted in orange, needs to be re-soldered to your new power cable.
Conclusione
William O'Brien
Membro da: 23/01/2018
473 Reputazione
4 Guide realizzate
Cal Poly, Team S1-G3, Livingston Winter 2018 Membro di Cal Poly, Team S1-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G3
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 21
Tutti i Tempi: 331
