Introduzione
The On/Off Switch for the Justin Bieber Concert Microphone allows the user to turn the device on and off. This is important to save battery and allow proper use of the device.
Cosa ti serve
Attrezzo utilizzato in questo passaggio:Flathead 1.5 mm Screwdriver$5.49
Remove the back panel of the device by unscrewing the single #8 11.6 mm Flathead screw on the back of the device.
Unscrew the other 4, #8 11.6 mm Phillips Head screws to remove the entire back half of the device.
Pull apart the device once screws are loose, splitting the device in half.
Keeping all wires connected to their attachments, place the front half of the device face down.
Remove the 2, #8 11.7 mm Phillips Head screws as well as the 2, #8 7.5 mm screws on the printed circuit board.
Remove the 2, #8 11.7 mm Phillips Head screws on the On/Off Switch Board
Remove On/Off Switch Board from its holding and detach the wires.
Replace the On/Off Switch Board with a new one and reattach the wires using this soldering guide
