Salta al contenuto principale
Jura Heater Replacement
Cosa ti serve
  1. Jura Heater Replacement, Jura Impressa Type C E F opening procedure: passo 1, immagine 1 di 1
    • The instructions are suitable for nearly every model of Jura and similar ones e.g. AEG and Krups.
    • Unplug!
    • Remove the water reservoir.
    Chiedi a FixBot
    Aggiungi Commento
  2. Jura Heater Replacement: passo 2, immagine 1 di 3 Jura Heater Replacement: passo 2, immagine 2 di 3 Jura Heater Replacement: passo 2, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    • On the rear side is an obstacle: four "oval head screws" looking like rivets. You can remove them using a special oval drive bit. They are sold at iFixit with the tool kits as well as some Jura suppliers or somewhere in the internet. Jura wants to keep us out of our own machines!
    • Using an oval head bit you can screw them out. If you haven´t got one you can carefully use pliers. It is a good idea to later change the screws for normal ones.
    • You can even create your own specialty tool
    • Beneath both top side covers are two Torx T15 screws. Remove those. Now lift off the whole top cover. Sometimes it jams and you have to use a bit of force.
    • The side covers must be pushed backwards by about 1 cm. Sometimes this is a little bit difficult to move. If necessary, wedge a plastic opening tool into the gap between the side covers and the front panel. The rear cover can be easily removed.
    Chiedi a FixBot
    Aggiungi Commento
  3. Jura Heater Replacement, Pull the plug!!: passo 3, immagine 1 di 1
    • Is the plug really pulled?
    Chiedi a FixBot
    Aggiungi Commento
  4. Jura Heater Replacement, The thermoblock: passo 4, immagine 1 di 3 Jura Heater Replacement, The thermoblock: passo 4, immagine 2 di 3 Jura Heater Replacement, The thermoblock: passo 4, immagine 3 di 3
    • The block is marked red here.
    • Older models have a completely differently shaped thermoblock. (Pictures 3). The guide for this you can find here.
    • There are three connections for water or steam.
    • Three cable feeders.
    • A thermocouple.
    Chiedi a FixBot
    Aggiungi Commento
  5. Jura Heater Replacement, Release connections: passo 5, immagine 1 di 3 Jura Heater Replacement, Release connections: passo 5, immagine 2 di 3 Jura Heater Replacement, Release connections: passo 5, immagine 3 di 3
    • First, pull the clips on the tubing connectors, then pull out the tubing.
    • Then remove the power cables: A gray cable leading to the thermal fuse, a blue one directly from the heater (can also be pulled later) and the green-yellow protective cable is unscrewed.
    • Two small blue cables lead to the temperature sensor, it is unscrewed.
    • The hexagon screw in the middle can be loosened.
    • Unscrew the tube holder, then the block is free.
    Chiedi a FixBot
    Aggiungi Commento
  6. Jura Heater Replacement, exchange: passo 6, immagine 1 di 1
    • Here lies the block. If you are lucky you can push out blockages from the openings with a wire. Mostly that does not work. The block can not be opened and must then be replaced.
    • This is the thermal fuse. First remove the cable lug, then unscrew and fix together with the cable on the new block, as well as the yellow-green protective cable.
    Chiedi a FixBot
    Aggiungi Commento
  7. Jura Heater Replacement, Assembly of the new block 1: passo 7, immagine 1 di 3 Jura Heater Replacement, Assembly of the new block 1: passo 7, immagine 2 di 3 Jura Heater Replacement, Assembly of the new block 1: passo 7, immagine 3 di 3
    • For mounting, the light carrier must be pulled out by loosening the marked screw.
    • It is attached with two hooks, you can lift them with a screwdriver.
    • The steam valve is actuated by a plastic disc with a cross-shaped cut. To loosen, you have to pull the whole front wall carefully outwards, then you can pull out the entire unit.
    Chiedi a FixBot
    Aggiungi Commento
  8. Jura Heater Replacement, Assembly of the new block 2: passo 8, immagine 1 di 1
    • Now you can see why all this was necessary: on the back of the carrier is a recess. Inside is loosely the lock nut to the big screw with which the block is attached.
    • Thus, first the new block is screwed into the carrier.
    • And now go through all the steps again in reverse order!
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Repeat the steps in reverse order to reassemble your device.
Altre 5 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
de en
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
VauWeh
Membro da: 10/19/15
330.521 Reputazione
311 guide realizzate
2Commenti sulla guida
I would love to see a disassembly of the Jura pancake-style Thermoblock to Rebuild the seals. Great work!
Lisa W - Rispondi Condividi
Thank you. :-) . Pancake style, thats funny. Next time I have one under my screwdrivers I'll shoot some pictures.
VauWeh - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 34
Ultimi 30 giorni: 127
Tutti i Tempi: 9,586
