Introduzione
While this guide is essential to replacing many parts on the Jawbone MINI JAMBOX, it requires an advanced level of technical knowledge. Only attempt to remove the motherboard if it is absolutely necessary.
Ricambi
Nessuna parte specificata.
Using the standard metal spudger, begin by prying at the bottom of the plain rubber end cap (the end without the USB or auxiliary input).
Remove all connecting ribbons from the motherboard.
One ZIF or "zero insertion force" ribbon connecting at the side.
One standard ribbon connector in the middle (Note: this ZIF ribbon is lightly glued to the surface).
Altre 5 persone hanno completato questa guida.
