Salta al contenuto principale
Jawbone Big Jambox Speaker Replacement
Cosa ti serve
  1. Jawbone Big Jambox Speaker Replacement, Outer Case: passo 1, immagine 1 di 1
    • Remove both end caps by putting a plastic opening tool in the center of the seam. Work around the edges to pry the end caps off completely.
    • Due to interior clips holding the end caps in place, use caution when applying force.
  2. Jawbone Big Jambox Speaker Replacement: passo 2, immagine 1 di 3 Jawbone Big Jambox Speaker Replacement: passo 2, immagine 2 di 3 Jawbone Big Jambox Speaker Replacement: passo 2, immagine 3 di 3
    • Turn the Jambox upside down. Peel the indicated rubber tabs off, using a plastic opening tool if necessary.
    • You may want to only take the tabs half way off to avoid re-gluing when reassembling.
    • Remove the three T6, 7.0 mm screws under each rubber tab.
    • Because the screws are a different length, set the screws aside.
  3. Jawbone Big Jambox Speaker Replacement: passo 3, immagine 1 di 3 Jawbone Big Jambox Speaker Replacement: passo 3, immagine 2 di 3 Jawbone Big Jambox Speaker Replacement: passo 3, immagine 3 di 3
    • With the Jawbone logo facing towards you and with correct orientation, place the Jambox with the left end cap facing upward.
    • Unscrew indicated T6 9.7 mm screws.
    • Gently loosen the tabs from their anchor points so the bottom may be removed.
    • Flip the Jambox so the other end cap is facing up. The USB cable is on this side (metal grounding clip, indicated in orange). Repeat the above two steps.
  4. Jawbone Big Jambox Speaker Replacement: passo 4, immagine 1 di 1
    • Pry up the bottom panel by lifting from the device.
    • Pull the bottom up. This may take a bit of force as the bottom is glued to device.
    • Once removed, the battery will now be visible.
  5. Jawbone Big Jambox Speaker Replacement: passo 5, immagine 1 di 2 Jawbone Big Jambox Speaker Replacement: passo 5, immagine 2 di 2
    • Before unscrewing, take a picture of the top view. That way, when you're reassembling the device, you'll know the orientation of the metal grounding plates.
    • Unscrew the eight indicated T6 9.8 mm screws. Remove metal grounding plates.
  6. Jawbone Big Jambox Speaker Replacement: passo 6, immagine 1 di 1
    • Once all eight screws are removed, pry the sides of the Jambox to lift the body from it's shell.
  7. Jawbone Big Jambox Speaker Replacement: passo 7, immagine 1 di 1
    • With the battery facing forward, remove the three indicated T6 9.5 mm screws.
    • Once the screws are removed, lift up the small plastic plate, revealing the auxiliary board underneath.
  8. Jawbone Big Jambox Speaker Replacement, Speaker: passo 8, immagine 1 di 3 Jawbone Big Jambox Speaker Replacement, Speaker: passo 8, immagine 2 di 3 Jawbone Big Jambox Speaker Replacement, Speaker: passo 8, immagine 3 di 3
    • Place the disassembled Jambox with the speakers facing up.
    • Locate the screws around the broken speaker.
    • Use a T15 screwdriver to remove the four 12.1 mm screws around the broken speaker.
  9. Jawbone Big Jambox Speaker Replacement: passo 9, immagine 1 di 1
    • Using a plastic opening tool, pry the speaker out of the Jambox.
  10. Jawbone Big Jambox Speaker Replacement: passo 10, immagine 1 di 2 Jawbone Big Jambox Speaker Replacement: passo 10, immagine 2 di 2
    • Desolder the wires from the speaker terminal in the Jambox.
    • Detach the round speaker from its square frame, and save the square frame for the replacement speaker.
    • Use caution when operating a soldering iron due to extreme heat.
    • For instructions on how to solder and desolder, take a look at the soldering guide.
Conclusione
Altre 12 persone hanno completato questa guida.
Taryn Kelley
Membro da: 04/01/15
672 Reputazione
1 Guida realizzata
Cal Poly, Team 24-5, Lancaster Spring 2015 Membro di Cal Poly, Team 24-5, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G5
4 Membri
9 Guide realizzate
14 Commenti
What is actual original speaker size and watts power?
Phinlander Betancur - Replica
Eu também gostaria de saber qual a potência e o tamanho exato do falante original para substituí-lo
I would also like to know the power and the exact size of the original speaker to replace it
francisnvieira - Replica
Does anyone know where to buy replacement speakers or for which they can be switched?
olivierdegruijter - Replica
@ Oliver,
I just wasted a pair of speakers because you mentioned those worked just fine for you. They are not the same sizes. it's smaller than the jamb speakers... On what basis you made that comment?
Kaveh Kadkhoda Zadeh - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 84
Tutti i Tempi: 22,627
