Introduzione
If the lights on the board aren’t working, the buttons on aren’t responsive, or Bluetooth is no longer functioning correctly, you may need to replace the motherboard. This guide will give you step-by-step instructions on how to replace the motherboard on the Jabra Speak 510.
Parti
Nessuna parte specificata.
Using a metal spudger, peel back the foam pad on the bottom of the device to reveal six screws.
Altre 3 persone hanno completato questa guida.
3 Commenti
Great walk-through... thanks
Be very careful when desoldering the connector cables! The soldering lugs are poor quality and tend to tear off the PCB
