Salta al contenuto principale
Jabra Speak 510 Motherboard Replacement
Cosa ti serve
  1. Jabra Speak 510 Motherboard Replacement, Outer Casing: passo 1, immagine 1 di 2 Jabra Speak 510 Motherboard Replacement, Outer Casing: passo 1, immagine 2 di 2
    • Using a metal spudger, peel back the foam pad on the bottom of the device to reveal six screws.
  2. Jabra Speak 510 Motherboard Replacement: passo 2, immagine 1 di 1
    • Remove the six 20 mm T6 screws from the bottom of the device.
  3. Jabra Speak 510 Motherboard Replacement: passo 3, immagine 1 di 2 Jabra Speak 510 Motherboard Replacement: passo 3, immagine 2 di 2
    • Remove the back plate and the grey foam underneath.
  4. Jabra Speak 510 Motherboard Replacement: passo 4, immagine 1 di 3 Jabra Speak 510 Motherboard Replacement: passo 4, immagine 2 di 3 Jabra Speak 510 Motherboard Replacement: passo 4, immagine 3 di 3
    • Use a small, pointed metal spudger to release the plastic tabs connecting the faceplate to the bottom of the speaker.
    • A small cable connects the faceplate to the device. Carefully disconnect the cable before fully opening the device.
    • Slowly flip the device open like a clam shell.
    • There are several wires soldered to the motherboard that prevent the faceplate from detaching completely.
  5. Jabra Speak 510 Motherboard Replacement, Motherboard: passo 5, immagine 1 di 2 Jabra Speak 510 Motherboard Replacement, Motherboard: passo 5, immagine 2 di 2
    • Using the T6 Torx Screwdriver, remove the four (4mm) screws.
  6. Jabra Speak 510 Motherboard Replacement: passo 6, immagine 1 di 1
    • After removing the screws, take out the center covering to free the motherboard by lifting the tabs and pulling it off.
  7. Jabra Speak 510 Motherboard Replacement: passo 7, immagine 1 di 2 Jabra Speak 510 Motherboard Replacement: passo 7, immagine 2 di 2
    • Peel off the white adhesive to desolder the connections underneath.
    • Desolder the wires connected to the motherboard.
    • You can find soldering tips in the How To Solder and Desolder Connections guide.
    • Keep track of where the wires are connected. When re-assembling you will have to connect the wires in the correct spot.
Conclusione
Altre 4 persone hanno completato questa guida.
IUPUI, Team 2-3, Harley Spring 2016 Membro di IUPUI, Team 2-3, Harley Spring 2016
IUPUI-HARLEY-S16S2G3
4 Membri
8 Guide realizzate
3 Commenti
Great walk-through... thanks
Walaa Maher - Replica
Be very careful when desoldering the connector cables! The soldering lugs are poor quality and tend to tear off the PCB
Thomas Sprenger - Replica
Hello
Where I can buy the motherboard replacement?
Regards
Lobo Gris - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 68
Tutti i Tempi: 7,420
