Salta al contenuto principale
JD Razor 2000 Front Wheel Replacement
Cosa ti serve
  1. JD Razor 2000 Front Wheel Replacement, Removing the 1.75" Axle Bolt: passo 1, immagine 1 di 3 JD Razor 2000 Front Wheel Replacement, Removing the 1.75" Axle Bolt: passo 1, immagine 2 di 3 JD Razor 2000 Front Wheel Replacement, Removing the 1.75" Axle Bolt: passo 1, immagine 3 di 3
    • Orient the scooter so that the front wheel is facing you. Observe the right and left side of the wheel. Remember which is which throughout the guide.
    • Using an Allen wrench, unscrew the axle bolt slowly from the right side while applying a constant pressure with your hand on the left side of the bearing.
    • If the left side of the bolt turns while you unscrew the right side, you will need to use a second Allen wrench to prevent it from moving
    • If the bolt does not move at all, or moves very little, try applying a lubricant on as much of the screw as possible and try again in 5 minutes.
    • Carefully pull apart the bolt and bearing from either side of the wheel.
    Chiedi a FixBot
    Aggiungi Commento
  2. JD Razor 2000 Front Wheel Replacement, Removing the Wheel: passo 2, immagine 1 di 1
    • Grip the bottom of the wheel and gently slide it out.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cal Poly, Team 4-46, Amido Fall 2014 Membro di Cal Poly, Team 4-46, Amido Fall 2014
CPSU-AMIDO-F14S4G46
4 Membri
16 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 47
Tutti i Tempi: 1,372
