Salta al contenuto principale
JBL Xtreme Charging Port Replacement
Cosa ti serve
  1. JBL Xtreme Charging Port Replacement, Cover: passo 1, immagine 1 di 1
    • Locate the seams next to the 'feet' on the bottom side of the device.
  2. JBL Xtreme Charging Port Replacement: passo 2, immagine 1 di 2 JBL Xtreme Charging Port Replacement: passo 2, immagine 2 di 2
    • Use the metal spudger to gently pry and lift the edge of the seam. The cover is held in place with plastic snaps that will make a popping noise when disengaged. !!Start with the back half, this will expose TWO Screws that need to be removed before lifting the front half.
  3. JBL Xtreme Charging Port Replacement: passo 3, immagine 1 di 2 JBL Xtreme Charging Port Replacement: passo 3, immagine 2 di 2
    • For the first part of the case: gently pull back the edges of the case rotating along the hinge opposite the opening seam illustrated in the second photo. Plastic snaps hold the cover in place.
    • For the second part of the case: there are 2 screws to be removed at the seam. Once removed, the case will come off completely without forcing.
  4. JBL Xtreme Charging Port Replacement, Bass Radiator: passo 4, immagine 1 di 3 JBL Xtreme Charging Port Replacement, Bass Radiator: passo 4, immagine 2 di 3 JBL Xtreme Charging Port Replacement, Bass Radiator: passo 4, immagine 3 di 3
    • Unscrew the six 9.75mm Phillips head screws holding the bass radiator in place.
    • Three of the five outer screws are indicated in the first image and the sixth inner screw is indicated in the second image.
  5. JBL Xtreme Charging Port Replacement: passo 5, immagine 1 di 3 JBL Xtreme Charging Port Replacement: passo 5, immagine 2 di 3 JBL Xtreme Charging Port Replacement: passo 5, immagine 3 di 3
    • Once the screws have been removed, the bass radiator will easily lift free.
    • Both radiators are identical. Repeat the above steps on the opposite radiator if necessary.
  6. JBL Xtreme Charging Port Replacement, Charging Port: passo 6, immagine 1 di 3 JBL Xtreme Charging Port Replacement, Charging Port: passo 6, immagine 2 di 3 JBL Xtreme Charging Port Replacement, Charging Port: passo 6, immagine 3 di 3
    • Locate and disconnect the the three plugs indicated in these pictures.
  7. JBL Xtreme Charging Port Replacement: passo 7, immagine 1 di 2 JBL Xtreme Charging Port Replacement: passo 7, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Unplug the three ports from the previous step.
    • A set of tweezers may be helpful to reach deeper into the device.
  8. JBL Xtreme Charging Port Replacement: passo 8, immagine 1 di 3 JBL Xtreme Charging Port Replacement: passo 8, immagine 2 di 3 JBL Xtreme Charging Port Replacement: passo 8, immagine 3 di 3
    • Locate the three Phillips head screws inside the zipper compartment and unscrew them.
    • Pull the zipper panel free from the device.
  9. JBL Xtreme Charging Port Replacement: passo 9, immagine 1 di 3 JBL Xtreme Charging Port Replacement: passo 9, immagine 2 di 3 JBL Xtreme Charging Port Replacement: passo 9, immagine 3 di 3
    • Under the zipper panel are eight more Phillips head screws. Unscrew them and carefully lift the battery cover.
    • Be careful not to damage the small white ribbon cable which connects the battery cover to the rest of the device.
  10. JBL Xtreme Charging Port Replacement: passo 10, immagine 1 di 2 JBL Xtreme Charging Port Replacement: passo 10, immagine 2 di 2
    • Unscrew the three 11.88mm Phillips head screws highlighted in the picture.
  11. JBL Xtreme Charging Port Replacement: passo 11, immagine 1 di 2 JBL Xtreme Charging Port Replacement: passo 11, immagine 2 di 2
    • Pull the Auxiliary board out.
    • There is foam covering the wires, making it difficult to remove the Auxiliary board. Take your time with this step.
  12. JBL Xtreme Charging Port Replacement: passo 12, immagine 1 di 3 JBL Xtreme Charging Port Replacement: passo 12, immagine 2 di 3 JBL Xtreme Charging Port Replacement: passo 12, immagine 3 di 3
    • The first image highlights the charging port.
    • Locate 6 metal pins highlighted in the second image and use a solder iron to disconnect the pins.
Conclusione
Altre 15 persone hanno completato questa guida.
Benny Huynh
Membro da: 02/15/17
1.953 Reputazione
4 Guide realizzate
USF Tampa, Team 1-1, Sullivan Spring 2017 Membro di USF Tampa, Team 1-1, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G1
4 Membri
27 Guide realizzate
Un commento
Please I have a JBL XTREME that sparks each time I plug it. What could be the cause
morris_ugwoke - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 59
Ultimi 30 Giorni: 242
Tutti i Tempi: 22,049
