Salta al contenuto principale
JBL On Stage II Power Jack Replacement
Cosa ti serve
  1. JBL On Stage II Power Jack Replacement, Cracking the Case: passo 1, immagine 1 di 1
    • Turn the device upside down so that the three rubber pads are facing up.
  2. JBL On Stage II Power Jack Replacement: passo 2, immagine 1 di 1
    • Use a heat gun (set to low) to apply heat to one of the rubber pads until you can easily remove the pad. This step takes around 5-7 minutes.
  3. JBL On Stage II Power Jack Replacement: passo 3, immagine 1 di 1
    • Remove the heated rubber pad with a plastic opening tool.
    • Repeat steps 2 and 3 for the two remaining rubber pads.
  4. JBL On Stage II Power Jack Replacement: passo 4, immagine 1 di 2 JBL On Stage II Power Jack Replacement: passo 4, immagine 2 di 2
    • Remove the six 1cm T-10 torx screws on the bottom of the device (found under the rubber pads) using a T-10 Torx screwdriver.
  5. JBL On Stage II Power Jack Replacement: passo 5, immagine 1 di 3 JBL On Stage II Power Jack Replacement: passo 5, immagine 2 di 3 JBL On Stage II Power Jack Replacement: passo 5, immagine 3 di 3
    • Open the device along its seam.
    • Be careful when separating the device because there are wires connecting the two seperate halves.
  6. JBL On Stage II Power Jack Replacement: passo 6, immagine 1 di 1
    • Disconnect the ribbon cable connector from the top half of the device by pulling outward and parallel to the connecting pins.
  7. JBL On Stage II Power Jack Replacement: passo 7, immagine 1 di 2 JBL On Stage II Power Jack Replacement: passo 7, immagine 2 di 2
    • Locate and disconnect the two molex connectors found on either side of the ribbon cable connector on the bottom half of the device.
  8. JBL On Stage II Power Jack Replacement, Circuit Board: passo 8, immagine 1 di 2 JBL On Stage II Power Jack Replacement, Circuit Board: passo 8, immagine 2 di 2
    • Remove the three 1 cm T-10 Torx screws.
  9. JBL On Stage II Power Jack Replacement: passo 9, immagine 1 di 1
    • Carefully press out the white base tube and push up on the circuit board.
    • Note that there is a small wire connecting the circuit board to the base.
  10. JBL On Stage II Power Jack Replacement: passo 10, immagine 1 di 2 JBL On Stage II Power Jack Replacement: passo 10, immagine 2 di 2
    • Pull the white wire out of the hot glue.
  11. JBL On Stage II Power Jack Replacement: passo 11, immagine 1 di 3 JBL On Stage II Power Jack Replacement: passo 11, immagine 2 di 3 JBL On Stage II Power Jack Replacement: passo 11, immagine 3 di 3
    • Unbolt the heatsink with a 5.5-mm socket and a Phillips PH1 screwdriver.
    • Remove the heat sink; it should detach from the bottom of the device.
  12. JBL On Stage II Power Jack Replacement: passo 12, immagine 1 di 3 JBL On Stage II Power Jack Replacement: passo 12, immagine 2 di 3 JBL On Stage II Power Jack Replacement: passo 12, immagine 3 di 3
    • Remove the T-10 torx screw on the bottom of the device that attaches the base tube to the circuit board.
    • Turn the device so that the base tube is on top.
    • Remove the base tube by pulling up.
    • May need to cut the rubber adhesive between the base tube to the circuit board.
  13. JBL On Stage II Power Jack Replacement, Power Jack: passo 13, immagine 1 di 3 JBL On Stage II Power Jack Replacement, Power Jack: passo 13, immagine 2 di 3 JBL On Stage II Power Jack Replacement, Power Jack: passo 13, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Desoldering Pump
    $3.99
    Compra
    • Turn the device upside down.
    • Solder the back lead of the power jack until the solder melts.
    • Heat the lead until the solder melts.
    • Remove the solder with the desoldering pump.
    • For help with soldering view the iFixit soldering guide
  14. JBL On Stage II Power Jack Replacement: passo 14, immagine 1 di 1
    • Repeat step 13 for the other two leads
  15. JBL On Stage II Power Jack Replacement: passo 15, immagine 1 di 1
    • Remove the power jack.
Conclusione
Replace the power jack with the new jack and resolder the leads. Follow the steps in reverse order to reassemble your device
Cal Poly, Team 9-28, Maness Winter 2014 Membro di Cal Poly, Team 9-28, Maness Winter 2014
CPSU-MANESS-W14S9G28
4 Membri
7 Guide realizzate
Un commento
Do you know where to find a sound jack for my JBL On Stage? Thanks
David Díaz - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,143
