Salta al contenuto principale
JBL Clip Plus Speaker Replacement
Cosa ti serve
  1. JBL Clip Plus Speaker Replacement, Battery: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    $3.99
    Compra
    • Use the angled tweezers to carefully pull the rubber bumper off the back side of the device
  2. JBL Clip Plus Speaker Replacement: passo 2, immagine 1 di 1
    • There will be three 6mm philips head screws under that rubber bumper, remove these three screws.
  3. JBL Clip Plus Speaker Replacement: passo 3, immagine 1 di 1
    • The back cover should lift open easily and the components should be visible.
  4. JBL Clip Plus Speaker Replacement: passo 4, immagine 1 di 1
    • The battery is adhered to the back cover of the JBL Clip Plus, slowly lift the battery away from the case, using a spudger to pry the battery away from the adhesive.
  5. JBL Clip Plus Speaker Replacement: passo 5, immagine 1 di 1
    • Remove the three 7mm philips head screws on the outer edges of the device.
  6. JBL Clip Plus Speaker Replacement: passo 6, immagine 1 di 1
    • Use the plastic prying tool to gently remove the face of the speaker from the body.
  7. JBL Clip Plus Speaker Replacement: passo 7, immagine 1 di 1
    • Use the spudger tool to gently scrape away the adhesive holding in the microphone.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  8. JBL Clip Plus Speaker Replacement: passo 8, immagine 1 di 1
    • Gently push the motherboard away from the microphone, this will allow you to remove the microphone.
  9. JBL Clip Plus Speaker Replacement: passo 9, immagine 1 di 1
    • Gently push the motherboard out from the frame of the JBL Clip Plus, this requires some force.
  10. JBL Clip Plus Speaker Replacement: passo 10, immagine 1 di 1
    • There are three solder points that need to be desoldered.
    • If you need help with desoldering refer to How to Solder and Desolder Connections help. After these are removed the battery should be free.
  11. JBL Clip Plus Speaker Replacement, Speaker: passo 11, immagine 1 di 1
    • There are two #1 philips head 4mm screw fastening the speaker to the body, remove these.
  12. JBL Clip Plus Speaker Replacement: passo 12, immagine 1 di 1
Conclusione
Altre 4 persone hanno completato questa guida.
Noah Pauk
Membro da: 02/08/16
809 Reputazione
3 Guide realizzate
IUPUI, Team 3-4, Baechle Spring 2016 Membro di IUPUI, Team 3-4, Baechle Spring 2016
IUPUI-BAECHLE-S16S3G4
4 Membri
6 Guide realizzate
2 Commenti
do you know were can i buy the new speaker for my jbl clip +?
ruitherock - Replica
I work in A/V. I frequently need to adjust audio systems.
I want to add a switch to the speaker wire, so I can turn the speaker off, and use the line out port only, in order to test audio systems with a Bluetooth reciver.
I can be at the mixing board, adjusting sliders while the music is playing, with no cables.
Will this work?
Donald Fournier - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 6,877
