Salta al contenuto principale
JBL Clip Plus Microphone Replacement
Cosa ti serve
  1. JBL Clip Plus Microphone Replacement, Battery: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    $3.99
    Compra
    • Use the angled tweezers to carefully pull the rubber bumper off the back side of the device
  2. JBL Clip Plus Microphone Replacement: passo 2, immagine 1 di 1
    • There will be three 6mm philips head screws under that rubber bumper, remove these three screws.
  3. JBL Clip Plus Microphone Replacement: passo 3, immagine 1 di 1
    • The back cover should lift open easily and the components should be visible.
  4. JBL Clip Plus Microphone Replacement: passo 4, immagine 1 di 1
    • The battery is adhered to the back cover of the JBL Clip Plus, slowly lift the battery away from the case, using a spudger to pry the battery away from the adhesive.
  5. JBL Clip Plus Microphone Replacement: passo 5, immagine 1 di 1
    • Remove the three 7mm philips head screws on the outer edges of the device.
  6. JBL Clip Plus Microphone Replacement: passo 6, immagine 1 di 1
    • Use the plastic prying tool to gently remove the face of the speaker from the body.
  7. JBL Clip Plus Microphone Replacement: passo 7, immagine 1 di 1
    • Use the spudger tool to gently scrape away the adhesive holding in the microphone.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  8. JBL Clip Plus Microphone Replacement: passo 8, immagine 1 di 1
    • Gently push the motherboard away from the microphone, this will allow you to remove the microphone.
  9. JBL Clip Plus Microphone Replacement: passo 9, immagine 1 di 1
    • Gently push the motherboard out from the frame of the JBL Clip Plus, this requires some force.
  10. JBL Clip Plus Microphone Replacement: passo 10, immagine 1 di 1
    • There are three solder points that need to be desoldered.
    • If you need help with desoldering refer to How to Solder and Desolder Connections help. After these are removed the battery should be free.
  11. JBL Clip Plus Microphone Replacement, Microphone: passo 11, immagine 1 di 1
Conclusione
Noah Pauk
Membro da: 02/08/16
809 Reputazione
3 Guide realizzate
IUPUI, Team 3-4, Baechle Spring 2016 Membro di IUPUI, Team 3-4, Baechle Spring 2016
IUPUI-BAECHLE-S16S3G4
4 Membri
6 Guide realizzate
Un commento
Love the sound of this speaker but I would like to disable the bluetooth signals. I only need and use the cable connection. I have contacted the manufacturer about this and they said the bluetooth cannot be disabled at the present set-up. Would you please show me how to disable or remove the bluetooth?
Mic - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,874
