Salta al contenuto principale
JBL Clip 3 Motherboard Replacement
Cosa ti serve
  1. JBL Clip 3 Motherboard Replacement, Speaker Grill: passo 1, immagine 1 di 2 JBL Clip 3 Motherboard Replacement, Speaker Grill: passo 1, immagine 2 di 2
    • Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
    • A strong adhesive attaches the grill to the housing, and requires some time and patience to break. Use mild heat to loosen the adhesive if necessary.
  2. JBL Clip 3 Motherboard Replacement, Speaker Housing: passo 2, immagine 1 di 2 JBL Clip 3 Motherboard Replacement, Speaker Housing: passo 2, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
  3. JBL Clip 3 Motherboard Replacement: passo 3, immagine 1 di 1
    • Separate the speaker housing from the rest of the body.
    • This requires minimal force; they are not glued together.
  4. JBL Clip 3 Motherboard Replacement: passo 4, immagine 1 di 2 JBL Clip 3 Motherboard Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to remove the 2 pin and 4 pin connectors from the motherboard.
  5. JBL Clip 3 Motherboard Replacement, Carabiner Clip: passo 5, immagine 1 di 2 JBL Clip 3 Motherboard Replacement, Carabiner Clip: passo 5, immagine 2 di 2
    • Lift the metal carabiner clip from the speaker housing.
    • They are not glued together and should separate easily.
    • There are alignment tabs on the clip so the whole assembly will only reassemble in one orientation.
  6. JBL Clip 3 Motherboard Replacement, Motherboard: passo 6, immagine 1 di 2 JBL Clip 3 Motherboard Replacement, Motherboard: passo 6, immagine 2 di 2
    Compra
    • Use a pair of tweezers to release the two cable connections from the motherboard.
    • The wires connecting to the battery are not very long, so be careful when removing them.
  7. JBL Clip 3 Motherboard Replacement: passo 7, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove the four screws.
  8. JBL Clip 3 Motherboard Replacement: passo 8, immagine 1 di 2 JBL Clip 3 Motherboard Replacement: passo 8, immagine 2 di 2
    • Lift the motherboard away from the speaker housing.
    • Desolder the two contact points.
Conclusione
Tyler Molden
Membro da: 03/28/22
492 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 20
Tutti i Tempi: 707
