Salta al contenuto principale
JBL Charge 5 Charging Port Assembly Replacement
Cosa ti serve
  1. JBL Charge 5 Charging Port Assembly Replacement, Fabric Case: passo 1, immagine 1 di 3 JBL Charge 5 Charging Port Assembly Replacement, Fabric Case: passo 1, immagine 2 di 3 JBL Charge 5 Charging Port Assembly Replacement, Fabric Case: passo 1, immagine 3 di 3
    • Ensure that the device is fully powered off and no cables are attached before proceeding with the repair.
    • This fabric cover is secured with plastic clips only. Depending on the model, the cover may be secured by both plastic clips and screws.
    • Insert the flat end of the Jimmy into the seam located between the fabric cover on the right side of the seam.
    • Pry upward on the fabric cover to release plastic clips on the right side of the seam.
  2. JBL Charge 5 Charging Port Assembly Replacement: passo 2, immagine 1 di 3 JBL Charge 5 Charging Port Assembly Replacement: passo 2, immagine 2 di 3 JBL Charge 5 Charging Port Assembly Replacement: passo 2, immagine 3 di 3
    • Insert the flat end of the Jimmy into the seam between the fabric cover at the center of the seam and the left side of the seam.
    • Use the Jimmy to pry open the edge with the rubber texture, releasing the remaining plastic clips.
  3. JBL Charge 5 Charging Port Assembly Replacement: passo 3, immagine 1 di 3 JBL Charge 5 Charging Port Assembly Replacement: passo 3, immagine 2 di 3 JBL Charge 5 Charging Port Assembly Replacement: passo 3, immagine 3 di 3
    • Use your hands to gently open the two halves of the casing and slide the fabric cover off of the interior housing.
  4. JBL Charge 5 Charging Port Assembly Replacement, Charging Port Assembly: passo 4, immagine 1 di 3 JBL Charge 5 Charging Port Assembly Replacement, Charging Port Assembly: passo 4, immagine 2 di 3 JBL Charge 5 Charging Port Assembly Replacement, Charging Port Assembly: passo 4, immagine 3 di 3
    • Use a Phillips #0 screwdriver to remove the four 10.6 mm screws on the charging port cover.
  5. JBL Charge 5 Charging Port Assembly Replacement: passo 5, immagine 1 di 3 JBL Charge 5 Charging Port Assembly Replacement: passo 5, immagine 2 di 3 JBL Charge 5 Charging Port Assembly Replacement: passo 5, immagine 3 di 3
    • Use the opening tool or spudger to undo the clips.
    • Do not immediately remove the charging port.
  6. JBL Charge 5 Charging Port Assembly Replacement: passo 6, immagine 1 di 3 JBL Charge 5 Charging Port Assembly Replacement: passo 6, immagine 2 di 3 JBL Charge 5 Charging Port Assembly Replacement: passo 6, immagine 3 di 3
    • Rotate the device to the left, and push the left passive bass radiator off of the frame of the device using the metal spudger.
  7. JBL Charge 5 Charging Port Assembly Replacement: passo 7, immagine 1 di 3 JBL Charge 5 Charging Port Assembly Replacement: passo 7, immagine 2 di 3 JBL Charge 5 Charging Port Assembly Replacement: passo 7, immagine 3 di 3
    • Pinch the charging port connector and gently remove the blue and black no-fuss ribbon cable from the board.
    • Pinch the connector with both fingers when removing it to ensure the ribbon cable will not tear.
  8. JBL Charge 5 Charging Port Assembly Replacement: passo 8, immagine 1 di 3 JBL Charge 5 Charging Port Assembly Replacement: passo 8, immagine 2 di 3 JBL Charge 5 Charging Port Assembly Replacement: passo 8, immagine 3 di 3
    • Using both fingers, remove the charging port assembly.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 150
Tutti i Tempi: 675
