Salta al contenuto principale
JBL Charge 4 Speaker Replacement
Cosa ti serve
  1. JBL Charge 4 Speaker Replacement, Speaker Grill: passo 1, immagine 1 di 1
    • Flip your speaker over and insert the plastic opening tool into the slit on the grille.
    • Pry away from yourself towards the back of the speaker to release the clip.
    • Repeat this process for the clip on the other side.
  2. JBL Charge 4 Speaker Replacement: passo 2, immagine 1 di 2 JBL Charge 4 Speaker Replacement: passo 2, immagine 2 di 2
    • Remove the two 8mm Phillips #0 screws from the other edge of the grille.
  3. JBL Charge 4 Speaker Replacement: passo 3, immagine 1 di 1
    • Pull apart both sides of the grille.
    • Lift the cover off of the speaker.
  4. JBL Charge 4 Speaker Replacement, Passive Bass Radiators: passo 4, immagine 1 di 2 JBL Charge 4 Speaker Replacement, Passive Bass Radiators: passo 4, immagine 2 di 2
    • Using the plastic opening tool, lift the tab on top of the speaker to release the radiator from the clips.
    • Repeat this process on the other clips around the radiator to release it from the frame.
  5. JBL Charge 4 Speaker Replacement: passo 5, immagine 1 di 2 JBL Charge 4 Speaker Replacement: passo 5, immagine 2 di 2
    • Push the radiator off of the frame of the device.
    • Repeat on the other side.
    • The passive bass radiators seal out water from inside the device. Removing them multiple times may compromise the waterproof nature of the speaker.
  6. JBL Charge 4 Speaker Replacement, Speaker: passo 6, immagine 1 di 2 JBL Charge 4 Speaker Replacement, Speaker: passo 6, immagine 2 di 2
    • Flip the device so that the speaker faces you.
    • Remove the four 8mm Phillips #1 screws.
  7. JBL Charge 4 Speaker Replacement: passo 7, immagine 1 di 1
    • Gently pull out the speaker.
  8. JBL Charge 4 Speaker Replacement: passo 8, immagine 1 di 2 JBL Charge 4 Speaker Replacement: passo 8, immagine 2 di 2
    • Desolder the red and black wires.
    • A guide for soldering and desoldering can be found here.
Conclusione
Altre 10 persone hanno completato questa guida.
Rohith Dara
Membro da: 01/24/19
357 Reputazione
1 Guida realizzata
Cal Poly, Team S1-G1, White Winter 2019 Membro di Cal Poly, Team S1-G1, White Winter 2019
CPSU-WHITE-W19S1G1
4 Membri
26 Guide realizzate
11 Commenti
Perfect - But where to get the replacement speaker ??? I’ve searched whole web. Please give me the info about replacement speaker diaphragm. Regards, T
Tadej Tomašič - Replica
Jbl charge 4 Led indicator board G ribbon cable authentic
carlos maltez - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 49
Ultimi 30 Giorni: 200
Tutti i Tempi: 23,058
