Introduzione
The charging port bay contains the USB-C port required to charge your JBL Charge 4. It also includes an AUX port to play music and a USB out port to charge your device. If one or more of these ports is not working this guide will show you how to replace them. This guide requires knowledge of desoldering. Find a guide on soldering and desoldering here.
Cosa ti serve
Flip your speaker over and insert the plastic opening tool into the slit on the grille.
Pry away from yourself towards the back of the speaker to release the clip.
Repeat this process for the clip on the other side.
Using the plastic opening tool, lift the tab on top of the speaker to release the radiator from the clips.
Repeat this process on the other clips around the radiator to release it from the frame.
Remove the two 6mm Phillips #0 screws from either side to remove the port bay cover.
Altre 11 persone hanno completato questa guida.
9 Commenti
Does anybody know which exact ports I have to get? There are a ton of different models out there.
You can purchase charging sockets from ebay by searching for "jbl charge 4 usb-c port" (without the quotation marks) or if you don't feel like replacing the charging port yourself, there are mail-in repair services available also.
Simon -
Ersatzteil:
✅ JBL Charge 4 Bluetooth Lautsprecher Micro USB C Buchse Ladebuchse Connector
https://www.ebay.de/itm/164897748374
Falls Sie beim Austausch der Buchse Hilfe benötigen:
✅ REPARATUR Austausch Micro USB C Buchse Ladebuchse Anschluss Port JBL Charge 4
