Salta al contenuto principale
Installazione dell'SSD nel MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260
Cosa ti serve
  1. Installazione dell'SSD nel MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260, Batteria: passo 1, immagine 1 di 3 Installazione dell'SSD nel MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260, Batteria: passo 1, immagine 2 di 3 Installazione dell'SSD nel MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260, Batteria: passo 1, immagine 3 di 3
    • Premere con le dita entrambe le linguette di sgancio della batteria verso l'esterno e sollevare la batteria dal computer.
    Before start, make a clone of your old HD into the new one, if you don't want to initiate a fresh copy. (Carbon Copy software is good).
    ColmillodeChile - Replica
    Besides using WD 500GB models, are the WD 640GB and WD 750GB (the 9.5mm thickness model) good to go for? I am still considering as I have heard from other websites on the computer does not draw enough power to power up the 640 and 750 as it has the clicking sound and the rainbow keeps appearing. Anyone has install one before yet?
    Please advice. Appreciated! Thanks a million to all the Mac gurus out there!
    Danny Lim -
    Citazione da ColmillodeChile:
    What is this about removing the PRAM battery causing a reinitialization of the HDD? For serious?
    Adrian - Replica
    No, that's nonsense
    max damage -
    Citazione da Adrianthomaspre:
    Wait, I misunderstood you. I thought the comment was directed at the PRAM battery removal page. Silly me.
    Nevermind. Yes, it is always a good idea to backup one's data before doing stuff like this. I never do, and have never had any problems, but it's still a good idea.
    Adrian - Replica
    The two screws removed in step 3 should not be mixed with screws in steps 5 through 7. Though similar, they are actually slightly shorter and have a bigger head. If you put the longer screws back in here when reassembling, the button to unlatch the top will not work properly.
    Doug - Replica
    Citazione da Doug:
    I think you may have commented on the wrong page. This page only has 3 steps, and the screws are removed in step 2, not 3.
    (Installazione della memoria RAM nel MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260)
    Don - Replica
    I'm not sure how the user notes get attached to the various procedures here, but my comment does seem to show up properly when viewing the steps for Hard Drive Replacement. However, the number of the step may be off if viewed as part of another procedure.
    Citazione da Don:
    Doug - Replica
  2. Installazione dell'SSD nel MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260, Installazione della schermatura della memoria RAM nel MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: passo 2, immagine 1 di 2 Installazione dell'SSD nel MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260, Installazione della schermatura della memoria RAM nel MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: passo 2, immagine 2 di 2
    • Rimuovere le tre viti con testa a croce da 2 mm dallo sportello della memoria.
    • Sollevare lo sportello della memoria affinché sia possibile prenderlo e farlo scorrere verso di sé, estraendolo dall'alloggiamento.
    These screws are different from the rest, they should be kept separate from the others.
    foregoing-celery - Replica
    Replacing RAM on an A1226: The instructions said Phillips #00, but the screwdriver that fit the RAM Shield screws for me was a Phillips #0.
    dlyons - Replica
    Concur, my screws were Phillips #0 as
    Lee Haelters - Replica
  3. Installazione dell'SSD nel MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260, Installazione del case superiore nel MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: passo 3, immagine 1 di 1
    • Rimuovere le due viti con testa a croce da 2,8 mm nello scomparto della batteria in prossimità della chiusura.
    Keep these two Philips screws separate. The screws are approximately 0.5mm shorter in length. When using one or two of the other longer screws in the battery compartment when reassembling, the lid will not open because the screw(s) do yam the lid button.
    Peter van Nes - Replica
    I had a logic board replaced by Apple (bad nVidia GPU), and believe it or not the Apple tech mixed up the screws. My latch did not work as good until I discovered and swapped the misplaced screws.
    madmaxmedia - Replica
    No believe it or not about it! I had same board replacement job done, and a screw was angled and crossthreaded, and the memory cover was hacked into place with insulating sheet lifted and crumpled.
    Lee Haelters -
    I removed the memory here as you would normally if you were changing it.
    Mike Matthias - Replica
    Use #00 phillips bit
    Jace - Replica
  4. Installazione dell'SSD nel MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: passo 4, immagine 1 di 1
    • Rimuovere le 6 viti seguenti:
    • Due viti Torx T6 da 10 mm su entrambi i lati dello slot RAM.
    • Quattro viti con testa a croce da 14,5 mm lungo il cardine.
  5. Installazione dell'SSD nel MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: passo 5, immagine 1 di 1
    • Rimuovere le quattro viti con testa a croce da 3,2 mm dal lato della porta del computer.
    If you are using a muffin pan to keep removed parts separate (a method I recommend highly), note that Steps 5, 6, and 7 involve removing the same size screw—and thus you can put them all in the same pile. This is unlike just about every other part you will remove during this procedure.
    Matt McCaffrey - Replica
    Using shot glasses!
    peterbcpa -
    If you are a mac newbie like me take care when you reassemble not to insert a screw in the DVI display port screw holes (shame). I cannot manage to get it out anymore.
    tai manu - Replica
    I did the same thing once, and eventually got it out. Try tweezers, a screwdriver, magnets, holding the MBP on its side so gravity is working with you, etc. Eventually the little bugger will come out, you just have to keep working at it.
    madmaxmedia -
    It would be a good idea to put some sticky tape on those two DVI display port holes, so that you never make the mistake to insert (when reassemble) any of the screws!
    genik - Replica
    RE: Misplaced Screws in the DVI port, I was upgrading an early 2008 MacBook Pro with an SSD to get some more life out it, and sure enough, misplaced one of these small screws into the DVI port upon reassembly. Screwdrivers, shaking, gravity... nothing worked. UNTIL I went to my dad's house and his super-comprehensive workbench, where he found a small, high-pull magnet and the little bugger flew right out. Refrigerator magnets won't cut it, you will need a more powerful magnet, such as these: http://www.kjmagnetics.com/products.asp?...
    Hope this helps someone... it was an easy solution to a frustrating problem
    John Lee - Replica
  6. Installazione dell'SSD nel MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: passo 6, immagine 1 di 1
    • Ruotare il computer di 90 gradi e rimuovere le viti con testa a croce da 3,2 mm dalla parte posteriore del computer.
  7. Installazione dell'SSD nel MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: passo 7, immagine 1 di 1
    • Ruotare il computer di 90 gradi e rimuovere le viti con testa a croce da 3,2 mm dalla parte laterale del computer.
  8. Installazione dell'SSD nel MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: passo 8, immagine 1 di 3 Installazione dell'SSD nel MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: passo 8, immagine 2 di 3 Installazione dell'SSD nel MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: passo 8, immagine 3 di 3
    • Non rimuovere il case superiore rapidamente, poiché è collegato alla scheda logica tramite un cavo piatto.
    • Sollevare il case dalla parte posteriore e, mediante le dita, liberarlo progressivamente dai lati. Dopo aver liberato i fianchi, potrebbe essere necessario inclinare il case verso l'alto e verso il basso per liberare la parte anteriore del case superiore.
    • Sono presenti quattro levette di plastica sopra lo slot del DVD e in alto e a sinistra del sensore infrarossi. Queste levette potrebbero essere difficili da sganciare senza fare leva. Inoltre, potrebbe essere difficile riagganciarle durante il riassemblaggio.
    • Suggerimento di riassemblaggio: Premere fortemente sulle estremità del case superiore verso il basso fino a sentire un schiocco per mettere le legame nelle corrispondente fessure.
    • Suggerimento di riassemblaggio: le due legame DVD della metà si raramente agganciano senza aiuto.
    • Attenzione non di distorcere il quadro attorno il DVD fianco con una pressione al ribasso. Sostenere il quadro: inserire una spatola di plastica negli i fianchi di DVD direttamente sotto la locazione delle legame fino è sicuro. Doppo, premere verso il basso fino a sentire un schiocco.
    The clips above the DVD slot (below the deck palm rest) are an absolute bear. They're hard to get released, and even harder to get back locked when you reassemble. (I've read to tilt the deck toward you when reassembling, inserting the front edge first, and press about an inch back from the edge to get all the front clips locked first before lowering the rest (back) of the deck.) No success for me yet, best of luck.
    sonofray - Replica
    I thought these two videos did an excellent job of showing the technique of removing and replacing the drive.
    MacBook Pro/PowerBook Keyboard Replacement (Part 1 of 3):
    http://www.youtube.com/watch?v=jUonF9OSv...
    MacBook Pro/PowerBook Keyboard Replacement (Part 3 of 3):
    http://www.youtube.com/watch?v=JWeFXWXpp...
    After watching that, I had the keyboard replaced in 2 minutes.
    Chris -
    the technique you describe of putting the front down first, is exactly what I did and it worked well
    dillonsavard -
    Those clips on the front edge are very challenging. I have a set of nylon pry tools that are for taking apart car dashboards without scratching the vinyl or plastic. I was able to get a long one in from the side and twist it which freed the clips without damaging the plastic on the upper case or the aluminum on the lower case.
    Putting it back together presented another challenge. When I first re-assembled it I think I pushed too hard over the DVD slot and accidentally bent the metal down. I was able to bend it back up using a thicker part of those same nylon pry tools, and then i was able to get it snapped back down successfully. Had I known this would happen, I would have just put the nylon tool in the slot to reinforce the metal as I was snapping the case back down.
    Nick - Replica
    As everyone has said, the front clips by the DVD can be really tight. Use the spudger to pry the top and bottom halves apart. Slow work it in from one side to separate the top and bottom.
    When reassembling the case, work the front clips by the DVD drive back in first. Once you slide them back in, the rest of the case fits easily.
    Ted Wise - Replica
    i've used an old atm card, it works fine.
    rotarypot - Replica
    I had a lot of trouble with getting those clips to lock in place again when reassembling. The way I eventually did it was to wedge something into the front of the CD/DVD slot so that I wouldn't warp the laptop casing. I used the end of a pen; when wedged in the tip of the pen was the right height to not support the casing above and below the CD/DVD slot and not allow it to warp.
    I simply ensured the pen was aligned with one particular clip, lifted the laptop slightly, and squeezed the top and bottom edge of the laptop casing very firmly at that point. Each clip clicked in quite easily doing it this way. Just remember to move the pen (or whatever you are using) along to whichever clip you are clicking in.
    David - Replica
    You're on the right track David. But what works really good is something that gets more surface area contact than the pen--I carefully insert a stack of 3" square post-it notes about 3/8" into the slot. And because they're stacked, you can easily add/subtract post-its to get as tight a fit as possible. Then, assuming you have everything lined up, use quite a bit of downward pressure. You should hear a few snaps as the clips reseat.
    Citazione da David:
    John Kassler Niemann - Replica
    John, I didn't think of that. But yeah you are right, it would give it a lot more support.
    David - Replica
    I have none of the problems above just was very careful, but inserting the palm rest in first does most of the work , gently does it looking at the alinement of the clips as you go straight in she goes!
    swissgrip - Replica
    I would agree with everyone that the clips above the DVD drive are very temperamental. They came off easily for me but were a pain getting to clip back in place correctly.
    Make sure you have the front clipped on securely before screwing the case back together otherwise the lid will not close properly.
    Nicolas - Replica
    I have taken apart quite a few laptops but this is my first Mac. This confirms my statements, to anyone that will listen, that these are the most "exquisite" machines ever produced. I just performed these HDD Replacement steps and with appropriate fear and trepidation popped the clips off. It would have been very helpful if someone had mentioned that they come straight up. I wasn't sure so I wiggled and (carefully) pried with the spudger until one of them went "POP". The credit card idea was helpful but my card was pretty soft so I didn't dare use it with too much force. When I got the top cover loose I just leaned it back against the screen so as not to take a chance on damaging the cable. Reassembly was according to the notes, but again the spudger was perfect if inserted into the drive slot (careful on the felt!) to support the base of the clips. Thanks to all for the notes. BTW; Prayer helps!
    mikedotten331 - Replica
    There is a fifth plastic clip between the IR sensor and the screw hole. (ie. 1 cm left of the IR sensor)
    On the top of the case mark the center of each of the four clips that are over the CD slot and the one clip to the left of the latch with a pencil. When re-installing the top case apply pressure over the clip to the left of the latch until you hear a snap. For the four clips over the CD slot, upend the entire case. Then insert the flat end of the spudger into the CD slot under the center of each clip. Apply pressure from the top of the case while providing support with the spudger in the CD slot until the clip snaps in. This will minimize the chances of bending the CD slot which would prevent CDs from ejecting.
    danno - Replica
    Take care reassembling new the DVD drive. It's easy to bend the top piece of metal down (the one that engages the clips) and your DVD can get stuck occasional ejecting. Very annoying. Maybe give it a little prophylactic bend upward. I placed a blunt letter opener in the slot and torqued it, while applying downward pressure from the top deck... This allowed the clips to engage nicely without bending this piece down.
    davidkkim - Replica
    I use the iSesamo tool to loose the clips, its a very good tool for this and many other things (I don´t work for iSesamo or iFixit hehe).
    araujogac - Replica
    i've used both of my inch nails, it works fine as well. no trouble to report.
    Caroline Masson - Replica
    i used a pry tool i had left over from replacing the screen on my iphone, any flat stiff item, like a credit card would work. watch the youtube video linked above, http://www.youtube.com/watch?v=jUonF9OSv..., skip ahead in the video to 4:57 where you see her use a pry tool. I had no problem separating and reassembling this section. Only issue i had was the two screws in the battery area. Only one of them would grab, so I left the other one out.
    owenmhv - Replica
    Here is an additional video showing how to remove the cables for both the left and right fans. At time 2:00 in the video he starts to work on the left fan. This video will help prevent you from attempting to detach the cables incorrectly.
    http://www.youtube.com/watch?v=apn3j3mAR...
    owenmhv - Replica
    I've opened these up many, many times, and by far the easiest method I have found to disengage the front clips is as follows:
    Lift up the top case by the rear corners near the hinge, keep lifting so the top case is tilting towards you. You will feel some resistance, but keep lifting and you will hear the clips disengage with a 'snap'. Doing it this way should not bend the top case metal or loosen the spacing between the top case metal and plastic trim. The clips will not break, they will still engage when you put the top case back on.
    It basically takes me 5 or 10 seconds to take off the top case now, and the case goes back on nice and tight as before.
    YMMV and all that, but that's my experience.
    Thank you for all the advance warnings, I had no issues with replacing the case. It just snapped into place with a little help from the spudger.
    acuella - Replica
    You're welcome! I was the one who added the spudger tips, as I had a devil of a time making the DVD drive clips snap back into place without one when I followed this guide.
    CaptFrost -
    Hello,
    I didn't have much problems reassembling the MacBook. Thanks a lot!
    For the hard reassembly part with the clips: I pushed quite hard with both thumbs directly over the place where the clips are. You need to figure out exactly where they are, but it worked well.
    I repeat it to make it clear: I pushed from the top on the location under which the clip sat, with two thumbs after having checked that the lid was well in place.
    My tools were one spudger and a basic tech toolkit from iFixit.
    Thanks a lot!
    momogingins - Replica
    I had not problem easing GENTLY the top case from the computer even around the DVD but I didn't understand how easy it was to disconnect the top case from the mother board. TAKE CARE HERE. It will make reassembly much easier it YOU get to disconnect the plug. See my note on step nine
    reb - Replica
  9. Installazione dell'SSD nel MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: passo 9, immagine 1 di 2 Installazione dell'SSD nel MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: passo 9, immagine 2 di 2
    • Scollegare il cavo piatto della tastiera e del trackpad dalla scheda logica, rimuovendo il nastro secondo necessità.
    • Nota: è possibile sostituire il disco rigido senza scollegare la tastiera dal case, tuttavia occorre tenerla in posizione sollevata affinché non sia d'intralcio e consenta di rimuovere il disco rigido con entrambe le mani.
    • Fare attenzione durante la rimozione del cavo piatto della tastiera e del trackpad e verificare che la parte posteriore del case superiore sia sganciata dalla zona in prossimità del cardine. I ricettacoli delle viti su entrambi i lati della tastiera sono facilmente soggetti a piegature accidentali.
    • Rimuovere il case superiore.
    If you does not have the spudger, use the Dremel to file a wooden piece
    (Chinese stick maybe) to transform in a spatula. Works fine for me
    If you don't have the magic "spudger," try using a plastic (eating) knife.
    jpkjpkjpk - Replica
    I read that you can actually also use the corner of a credit card. I didn't have a spudger and this worked perfectly for me. If you hold the card quite close to the corner and it has just the right amount of flex.
    David - Replica
    You may be able to unplug the ribbon connector by lifting each end of the tape.
    MrSafety - Replica
    Where can I get the cable from step 9 above?
    just broke it!
    Derry Manley - Replica
    That cable is attached to the upper case. It can be found here for the A1226 and here for the A1260.
    Andrew Bookholt -
    To unplug the cable, pull the black connector straight up from the logic board.
    Robert MacLeay - Replica
    These are instructions for the right Fan. Step 9 mentions the hard drive not the right fan.
    karen - Replica
    I didn`t need to unplugged the cable to change the right fan. As Karen wrote above, it is for a fan to change not necessary.
    I chose not to disconnect this ribbon cable. I used a chopstick to prop open the front panel; just gently place in lower right corned of case and upper right corner inside the top panel. Saves the risk of disconnecting.
    jimmora - Replica
    I didn't look well before the plug connecting top case to motherboard (see my note in step 8). When it came time for assembly it took a while for me to figure out when the plug connected in the motherboard. Take care on step 8 so that YOU have to make the disconnection in step 9. Then reassembly on this step will be much easier.
    reb - Replica
    Step 9, 2007 Mac Book Pro right fan replacement. It’s not necessary to disengage the keyboard ribbon, you can just tilt the upper shell back and support it against the screen. Be sure not to put tension on the ribbon and to check that the ribbon “plug” is seated securely on the base before reinstalling the top shell.
    These instructions were really great. For $15 I got a used fan off eBay and a Torx T6 driver and Phillips 00 driver from the hardware store. Thanks also for the comment about marking where the plastic clips are by the DVD and IR slot with pencil. When reassembling I slotted a piece of wood (kebab skewer) into the DVD slot and pressed down on the pencil mark with the eraser end of the pencil.
    My 10 year old MacBook Pro is going strong. Thanks for these very much. It was fun to do as well.
    Kirsten - Replica
    Hello, I have a MacBook like this but I have seen that in the part of the RAM on the right there is an elongated chip, I don't have it, that could cause the problem of no connection, what is the name of that chip, thank you
    Trepas - Replica
  10. Installazione dell'SSD nel MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260, Installazione del disco rigido nel MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: passo 10, immagine 1 di 2 Installazione dell'SSD nel MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260, Installazione del disco rigido nel MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: passo 10, immagine 2 di 2
    • Scollegare il cavo piatto arancione del disco rigido dalla scheda logica.
    • Rimuovere il nastro secondo necessità e utilizzare un inseritore (o inserire con attenzione una carta di credito sotto il nastro) per allentare con cautela l'adesivo che fissa i connettori del sensore infrarossi e della spia della modalità sospensione alla parte superiore del disco rigido.
    • Potrebbe essere meglio di rilasciare l'angolo sinistro prossima, e poi l'angolo retto, e poi il centro della banda, per l'affrontare da tutte le parti e per applicare gentilmente una forza sulla superficie collosa la più piccola.
    In my model the glue was really hard, if you think the tools you are using twist the cable too much try with a credit card.
    obsidianart - Replica
    Be careful, I made a mistake and ripped off the top part of the motherboard connector. Fortunately, i was able to find the part (harddrive cable) from some Internet vendor.
    roman7927 - Replica
    Citazione da roman7927:
    Agreed. I did the exact same thing. Be Careful!
    welhitamy - Replica
    A hint: to minimize any cosmetic gaps between the edges of the top and bottom case, firmly press down the top case with your fingers, squeezing the cases together at each location while installing the left and right side screws, especially toward the front of the computer.
    etnier - Replica
    etnier, i don't understand what you are suggesting
    roeishusel - Replica
    I got to this step, and to my dismay, I found that the Torx screws on the hard drive retaining bracket, and the new hard drive were NOT T6. The T6 screwdriver just goes around and around in them. Anyone else have this problem, and know the correct size? It was quite a bummer, since I had to reassemble the whole thing without having completed the project.
    ifixgrax - Replica
    Update: I bought a new Torx driver kit, and found that it actually IS a T6! I guess there are variations in how Torx screwdrivers fit into the nuts. Anyway, all seems good. My new 640GB drive is happy in its new home.
    ifixgrax - Replica
    If you are replacing the HD with a Seagate Momentus 7200 RPM 500 GB Hard Drive be careful not to cover drive's breath hole since the ribbon cable will exactly pass over it (where the sleep light and IR sensor connectors are). You need to paste it a little bit diagonal. Also as roman7927 and welhitamy said, be VERY careful when removing the ribbon cable from the motherboard, I ripped it off too!
    Good Luck.
    feribz - Replica
    I managed to change the hard drive, but with a different aproach on step 10. I did not disconect any of the cables from the motherboard, as I managed to slide the drive out, by lifting it a little, then disconecting only the hard drive cable with the help of the Spudger and slowly out. I think find it safer than removing the delicate conectors from the motherboard. Good luck!
    Bernak - Replica
    Citazione da Bernak:
    I followed this process and it worked seamlessly. As long as you have a soft touch you don't have to connect anything other than the hard drive cable and that proved very easy for me.
    Ben Kelly - Replica
    Slow and easy seems to be the key to separating the ribbon cable from the top of the drive. I used an alternating approach, emphasizing first one side and then the other of the cable, especially around the curve. The spudger and a plastic card were both useful here.
    i didn't prefered touch connector on the motherboard. slowly lift harddrive with fingers. be carefull.
    RAMBOSS HOME - Replica
    the tape to the sleeplight/IR will re-adhere & is best removed at step 11, when it can be folded neatly out of the way with the mother board connection under edge of computer case at LH of superdrive
    chris - Replica
    I did not need to disconnect the hadrdrive cable from the motherboard. I could carefully plug and unplug the hdd while the cable is still connected to the lower body. Less hassle and less things being able to break.
    tom - Replica
    As others here, the second time I replaced the internal drive I didn't disconnect the ribbon cable from the logic board. I was installing an SSD, so maybe it was a little easier than with an HD. However, I don't remember disconnecting and reconnecting the ribbon cable to be an issue.
    ngt - Replica
  11. Installazione dell'SSD nel MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: passo 11, immagine 1 di 3 Installazione dell'SSD nel MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: passo 11, immagine 2 di 3 Installazione dell'SSD nel MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: passo 11, immagine 3 di 3
    • Rimuovere le due viti Torx T6 da 8,2 mm che fissano la staffa di fissaggio del disco rigido al case inferiore.
    • Usare una spatola si il cavo nastro del disco rigido è fortemente incolloto sulla parte superiore del lettore. Attenzione di lavorare lentamente per evitare di danneggiarlo.
    • Sollevare la staffa di fissaggio del disco rigido e rimuoverla dal computer.
    • Sollevare il disco rigido con una mano e utilizzare l'altra per scollegare il relativo cavo.
    I used the round pointed part of the spudger (the opposite end of the one pictured in step 10) and started from the part of the cable that wasn't glued to the top of the hard drive. Insert the round pointed part under the bottom of the cable, perpendicular to it, and then roll it towards the glued part on the hard drive. The cable should separate quite easily from the drive . It was much easier doing it this way than using the chisel part of the spudger to separate the cable from the drive.
    mosburger - Replica
    I agree i managed this
    swissgrip - Replica
    I was having quite a go as well. This is a great tip. Took some time but nothing bent or broken and all is well =). Try different twirling/spinning techniques and be careful of the ribbon glue sticking to your HDD sticker.
    Imoviebob - Replica
    I had to unplug the IR receiver and sleep light connectors to be able to remove the drive. The connectors resist a little; just pull on them carefully but firmly with your fingernails.
    sjbufton - Replica
    My ribbon cable was well and truly glued, I watched a few vids on youtube and they were hardly stuck at all.
    But thanks to another comment on one of these guides for recommending DENTAL FLOSS!!
    (a shame there are three separate guides for the pre unibody mbp as many of the processes are the same)
    This worked like a dream, i took my time and used long strokes back and forth. Three frayed and snapped bits of floss later, eventually I was able to saw through the glue.
    Though be sure to have your compressed air to get rid of any fluff (and remember to put your tray of screws somewhere else when you do so :)
    Sam Turner - Replica
    I stupidly spent about 20 minutes trying to figure out how to pull the drive out when it was still screwed in on the left side, only to find that they're not screws but just rods that keep the drive in place. Hope this helps save people from making the same mistakes I did!
    marknolte1 - Replica
    My cable was truly glued on to the hard drive also. Fortunately it was glued to the metallic sticker identifying the HD. That is to say, the sticker with HD product info, serial number etc. I was able to lift the sticker (and used an exacto knife to strip parts of the sticker away). So instead of ungluing the cable from the sticker, I unstuck the sticker. Hope this helps someone.
    Apart from that slight trouble spot, the swap went well. I had previously cloned the drive and was able to start up with everything except MS Office working fine. MS Office asks for the product key as it detects that the computer is "different" because of the new drive.
    billvdg - Replica
    Try these Ulta Thin metal spudgers for iPhone repair. Thinner than a credit card, good grasping and slices thru the glue!
    https://www.amazon.com/Opening-Spudger-S...
    Macrepair SF - Replica
    @mac_medic Link doesn’t work
    mosburger -
    Be careful when you'll disconnect the SATA connector on the HDD itself: the area where the ribbon cable bends is quite prone to wear and tear.
    After several disassemblies, I actually broke that ribbon cable by making a slight "cut" on the junction between the upper part of the ribbon cable (the one which goes from the HDD to the motherboard) and the lower part (the one which goes to the latch LED and IR sensor).
    It took me quite some time to find that this ribbon cable was actually broken; as I had no HDD issues, I thought that it was fine. That's only when I found that I had no more latch LED and unrecognized IR sensor, that I carefully examined the ribbon cable, just to find that there was that little cut in the circuitry. Hopefully, I had a spare one, and you can still find it for a few bucks.
    maxime.abbey - Replica
  12. Installazione dell'SSD nel MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260, Installazione dell'SSD nel MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: passo 12, immagine 1 di 1
    • Rimuovere le due viti Torx T6 argentate da 6 mm dal lato sinistro del disco rigido.
    • Trasferire queste viti nel nuovo SSD.
    Any idea where I could purchase these screws? I shipped off my drive for replacement and forgot to remove them.
    paul - Replica
  13. Installazione dell'SSD nel MacBook Pro Core 2 Duo da 15" modelli A1226 e A1260: passo 13, immagine 1 di 1
    • Rimuovere le due viti Torx T6 nere e i due paracolpi in gomma bianchi dal lato destro del disco rigido.
    I replaced the 200 GB that came with the A1260 with WD 500GB, 5400 Blue drive. Thanks to this guide. Well written and quite helpful.
    After replacing the drive, I did the installation of Mountain Lion while the case is still open. Once I made sure that it is booting and etc., I closed the case. Now the machine never boots. Used the OS DVD to boot and install the OS. Installation log says 'Repairing Volume...'.
    In the past three days I went to the store and replaced three HDDs. Why the HDD fails once the case is closed? I am really frustruated. Please help. Thanks.
    -SSK
    SSK - Replica
    did it, easy-peasy compared to a 2007 MacBook (White Plastic)... installed a 256GB SSD, i came with a spacer to be 9,5mm thick.
    great guide!
    cheers from germany!
    wurstmoped - Replica
Conclusione
Per riassemblare il dispositivo, seguire queste istruzioni in ordine inverso.
Altre 1093 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
en it
100%
Oriane Petit ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
22 Commenti
Hi folks, is it possible to inserting a new 1 GB 2,5" HDD with a thickness of 12.5 mm into the MBP?
can anyone help me?
Sorry about my bad english...
Andreas from germany
Andreas Zowislo - Replica
Not to the pre-unibody MBPs it isn't possible, no. Maximum size 9.5 mm drives
Alex Jenner -
I used the A1260 hard drive replacement guide to swop out a Western Digital Scorpio SATA (WD3200BEVT) 320 Gig 5400rpm for a Western Digital SATA (ST9750420AS) Momentus 750 Gig 7200rpm. (http://www.seagate.com/www/en-us/product...) The whole operation went flawlessly thanks to the guide. The improvement in speed / access with the bigger, faster hard drive is very noticeable. Just to let people know that the installation of a 750 gig drive is an accomplished fact in a A1260 series MacBook Pro.
Uncle Jim - Replica
Thanks for the very thoroughly and easy-to-follow guide. I'm no technical genius, but thanks to the guide I manage to replace the original disc with a Toshiba THNS 512GG8BBAA. I printed out the instructions and attached the screws with scotch to the right picture as I went along - not a chance of mixing or loosing the screws. It all went well, and the improvement is awesome!
HansO - Replica
After some trepidation, it all came together flawlessly in about an hour. Great guide, and good advice in the notes about organizing those 27 screws. This will put at least another year of life in my aging Macbook.
Robert Lied - Replica
hello ifixit team,
today I have changed the default 250GB HDD (new: Seagate XT ST95005620AS 500GB SATAII 7200 4GB SSD) from my MacBookPro (4,1 / A1260 / A1260 / Early 2008) and upgraded the RAM to 6GB (2+4): It works!
Thanks for both tutorials the HDD replacement and the RAM upgrade. The "How To" is very good and all the necessary steps are perfect described.
It took not more than 30" at all.
Great job!
Regards HK
Hans - Replica
Sorry I forgot:
Now the MBP is so much faster than before. It's incredible. The first thing is the extremely short boot time and the second is the smooth working, because of the additional RAM and the super fast HDD (Hybrid with 4GB SSD).
Hans -
Great guide, thanks! I installed a new Seagate 750 Gb drive in about an hour, so finally I can copy my iTunes and iPhoto libraries back to my internal HD :)
There was only one unexpected thing: maybe because my mbp is 3.5 years old now and I've been using it a lot (and thus has spent quite a few hours being quite warm), the tape that secures the IR sensor and the sleep light cable to the top of the drive was almost fused with the plastic sticker that covered the old Fujitsu drive. Eventually I found that sliding a thin, sharp guitar pick under it and thus carefully separating it worked - almost as if cutting it loose.
See https://img.skitch.com/20111023-p4wdpnw5...
Luthien - Replica
Avoid touching the bottom (circuit board) on a harddrive; it might not be dead yet! Grasp the harddrive between thumb and fingers on the [longer] 9.5mm edges.
vendor02 - Replica
I used a very dull flat head for the glued wire, it was touch and go, clearly intended to be done by a rep. Thanks for this guide. I just swapped out this old beasts hard drive with a ssd for my wife to use and this guide saved me a lot of headache!!
mike - Replica
Are the particular specs I need to pay attention to when buying a SSD? (the controller is only SATA I so will a SATA II or III work?) I'm also watching the 9.5mm thickness. Anything else?
Thanks, Mike
Mike -
All ok with this guide. My only problem was that my macbook pro has some T7 torx and 000 Philips screws too.
danocho - Replica
Hi all
I will start first with my comment in English then in French :
I want to thank you ifixit for this guide, even if description has been in french, photos are perfect to understand in case of misunderstanding. Everything works fine ! My 2008 MBP is incredibly fast ! Benchmark from XBench is as least 10times more faster for SSD VS my old HD ! Applications launch in 2secs whereas it takes 12 using the HD !
Je remercie ifixit pour ce guide, et même si la description n'est pas en Français, les photos sont juste parfaites en cas de doute. Tout marche nickel ! Mon MBP 2008 est incroyablement rapide ! Un benchmark réalisé avec XBench indique que mon SSD fonctionne au minimum 10x plus vite que mon vieux DD ! Les application se lancent en 2 sec au lieu de 12 avec le DD !
See you soon for another fix I have to do :( -> home button of my iPhone4
A bientôt pour une nouvelle réparation :( -> bouton home de mon iPhone4 :(
Nicolecameleon - Replica
thank you very much.. I was with short of space.. with only 160GB.. I've successfully replaced my HDD to 320 GB from my external USB drive.. I'm very happy.
Now I 'll install windows 7 + Mavericks again.. :)
Thank you so much
Muhammad Farooqi - Replica
What is the actual max size hard drive (traditional and SSD) you can upgrade to on an A1260? The i fixit store says 1tb but forum posts say 750. There's a lot of good deals right now but I'd like to get max specs. Thanks!
JasonW - Replica
I replaced the internal drive two times (the first one it was a larger HD, the second time an SSD). This guide is absolutely fantastic! Thank you!
ngt - Replica
Thanks for the guide, everything worked out fine. Swapped in a SSD with no problems. BTW one of the steps needs a #000 Phillips screwdriver, and I didn't use the spacer that came included with my SSD drive.
MacBook Pro (15-inch Early 2008) / MacBookPro4,1
SanDisk Ultra II 240GB SDSSDHII-240G-G25
mt - Replica
Wow! I don't know why I waited so long. Everything went smoothly even snapping the top cover (step 8). My Macbook Pro is really snappy once again. And the 500GB drive I bought from iFixit is working great. Thank You! Thank You! You guys & gals at Ifixit are the best.
Shalabh Agarwal - Replica
Just to mention, be careful what drive caddy you buy, mine didn't work and I ended up putting my ssd in the regular drive slot. Now I have to wait until I can order the caddy again. Great guide mostly, worked out.
Maximillian Charles - Replica
I've never taken apart a computer before, but I needed to remove and destroy the hard drive before recycling the MacBook. Thank you for the highly detailed set of instructions. The last steps are probably better on video. but for what it is, this is nearly perfect.
Scott Robinson - Replica
Do we need an adapter for storage thinner than 9.5mm?
Philippe Morin - Replica
would the MX500 work for this procedure or it HAS to be a MX300?
David Apap - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 11
Ultimi 7 Giorni: 62
Ultimi 30 Giorni: 289
Tutti i Tempi: 740,827
