Introduzione
Use this guide to replace the antenna (responsible for receiving radio broadcasts) inside the Insignia Digital AM/FM Dual-Alarm Clock.
Always use CAUTION when self-repairing and follow the instructions closely to avoid potential damage to the device.
Cosa ti serve
Flip the clock over to expose the battery cover shown in the top left corner.
Turn the clock over and remove the 1cm screw with a Philips head screwdriver, which is located below the faceplate, on the bottom of the clock.
First, remove the front screen. (See prerequisite screen removal guide.)
Follow steps on removing the motherboard as a prerequisite.
Gently move the motherboard back, revealing the thin black wire that is the antenna. The antenna wire is, on the outside, located on the lower, middle back. Follow the wire from the outside to the inside to make sure it's the correct one.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Altre 2 persone hanno completato questa guida.
