Salta al contenuto principale
Insignia NS-CLLT01 Radio Antenna Replacement
Cosa ti serve
  1. Insignia NS-CLLT01 Radio Antenna Replacement, Insignia NS-CLLT01 Top Casing Removal: passo 1, immagine 1 di 2 Insignia NS-CLLT01 Radio Antenna Replacement, Insignia NS-CLLT01 Top Casing Removal: passo 1, immagine 2 di 2
    • Lift the four adhesive covers on each of the corners on the bottom of the clock using a plastic opening tool or your fingernail.
  2. Insignia NS-CLLT01 Radio Antenna Replacement: passo 2, immagine 1 di 3 Insignia NS-CLLT01 Radio Antenna Replacement: passo 2, immagine 2 di 3 Insignia NS-CLLT01 Radio Antenna Replacement: passo 2, immagine 3 di 3
    • On the bottom of the clock, use your fingernail to push the battery cover to the right.
    • Lift the battery cover up and to the right to reveal the batteries.
  3. Insignia NS-CLLT01 Radio Antenna Replacement: passo 3, immagine 1 di 1
    • Remove the two AA batteries by pressing the end opposite of the spring towards that spring and lifting up.
    • Once the batteries are removed, close the cover.
  4. Insignia NS-CLLT01 Radio Antenna Replacement: passo 4, immagine 1 di 1
    • Use a long Phillips #2 screwdriver to unscrew all six 10mm Phillips screws inside the bottom of the clock.
    • Turn over the device to allow the screws to fall out, being careful to catch them so that you do not lose any.
    • The screws may not come out of the bottom of the clock. As long as you have unscrewed them, the clock can still be opened.
  5. Insignia NS-CLLT01 Radio Antenna Replacement: passo 5, immagine 1 di 3 Insignia NS-CLLT01 Radio Antenna Replacement: passo 5, immagine 2 di 3 Insignia NS-CLLT01 Radio Antenna Replacement: passo 5, immagine 3 di 3
    • Turn the clock back over.
    • Lift the top off of the clock by gripping the back of the iPhone dock and pulling straight up.
  6. Insignia NS-CLLT01 Radio Antenna Replacement, Motherboard: passo 6, immagine 1 di 2 Insignia NS-CLLT01 Radio Antenna Replacement, Motherboard: passo 6, immagine 2 di 2
    • Grip the white ribbon cable connector that attaches the lightning cable to the middle of the central circuit board located in the bottom of the clock. Pinch and pull straight up to detach the cable.
  7. Insignia NS-CLLT01 Radio Antenna Replacement: passo 7, immagine 1 di 2 Insignia NS-CLLT01 Radio Antenna Replacement: passo 7, immagine 2 di 2
    • Remove the white ribbon connector that connects the central circuit board to the circuit board attached to the top of the clock by gripping it on both sides and pulling it straight away from the board.
  8. Insignia NS-CLLT01 Radio Antenna Replacement: passo 8, immagine 1 di 1
    • Unscrew the two 10mm screws from the bottom circuit board.
  9. Insignia NS-CLLT01 Radio Antenna Replacement: passo 9, immagine 1 di 3 Insignia NS-CLLT01 Radio Antenna Replacement: passo 9, immagine 2 di 3 Insignia NS-CLLT01 Radio Antenna Replacement: passo 9, immagine 3 di 3
    • Use the narrow end of a plastic spudger to pull back the clip in the center of the board.
    • At the same time, pry the circuit board up by wedging another spudger into the top left-hand corner of the board and working it along the back, pushing the edge of the board away from the back of the clock.
    • The black radio antenna, which is attached to the board and comes out of the back of the clock, will need to be pushed into the clock from the outside as the board is lifted up.
  10. Insignia NS-CLLT01 Radio Antenna Replacement: passo 10, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Once the ports on the back of the circuit board are displaced and resting against the back of the clock, use a pair of tweezers to lift the circuit board up off of the bottom of the clock, continuing to feed the radio antenna through the side of the clock as the board lifts up.
  11. Insignia NS-CLLT01 Radio Antenna Replacement: passo 11, immagine 1 di 1
    • Pull the radio antenna the rest of the way through the side of the clock.
  12. Insignia NS-CLLT01 Radio Antenna Replacement: passo 12, immagine 1 di 1
    • Turn the circuit board over.
    • Disconnect the two white connectors on the bottom of the circuit board by gripping the sides of each connector and pulling straight out.
  13. Insignia NS-CLLT01 Radio Antenna Replacement, Radio Antenna: passo 13, immagine 1 di 1
    • Turn the circuit board back over.
    • Use this soldering guide to remove and replace the radio antenna that is attached to the corner of the circuit board.
Conclusione
Baylor, Team 6-9, Williams Fall 2015 Membro di Baylor, Team 6-9, Williams Fall 2015
BU-WILLIAMS-F15S6G9
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 474
