Introduzione
If your tablet display is not functioning or the image is distorted, you may need to replace the screen.
Cosa ti serve
Use a plastic opening tool to remove the rear panel from the front case.
Insert the plastic opening tool between the front case and rear panel. Use a prying motion to lift the front case from the rear panel.
Work the tool around the perimeter of the device until the front and rear panels become separate.
Quasi finito!
Conclusione
