Introduzione
If your Insignia flex 10.1 NS-P16AT10 will not power on, you may need to replace your battery.
Cosa ti serve
Use a plastic opening tool to remove the rear panel from the front case.
Insert the plastic opening tool between the front case and rear panel. Use a prying motion to lift the front case from the rear panel.
Work the tool around the perimeter of the device until the front and rear panels become separate.
Quasi finito!
Conclusione
