Cosa ti serve
Using the plastic opening tool, remove screen protector from front of monitor.
Disconnect speaker from monitor for ease of access by unplugging wire.
Thank you so much for this - and thank you to the commenter who walked through the additional screen replacement steps! I’ve never done anything like this and I managed to replace the screen myself.
Unscrew the four 3 mm screws holding the motherboard to the unit using a Phillips #00 screwdriver.
Flip the unit over to ensure a correct fitment.
Where do you buy a new charging port? Also, you didn't include new charging port as an item that is needed for this tutorial. Might be self-explanatory but why say "no parts required" when clearly a part is required?
In any event, thanks for this tutorial. Much appreciated!
The part you are looking for is a female Micro USB B-Type solder socket. I no longer have the unit available to confirm, but I'll bet you could contact Infant Optics and confirm with them. Sorry I can't be of more help!
3Commenti sulla guida
I appreciate you posting this. What kind of new charging port did you use (USB type, size, etc) and does IFIXIT sell them?
Worth pointing out that this guide shows an older version of the DXR-8 (2014 printed on the PCB) where the microUSB port uses through-hole leads to connect to the board. Mine is a few years newer and the port was surface-mounted, which requires more skill and care to replace. I ended up ordering the part myself and taking it to a repair shop for them to do the soldering.
There's a layer of adhesive between the screen protector and the white plastic behind it.
Jared Astillero - Replica
The cover is glued on. So you’ll nee d quite a bit of force to bend it up. But then it’ll come lose glue point by glue point. At first I was afraid that I’ll break it.
Marco Smolla - Replica
