Salta al contenuto principale
IQ America VD-8810L Motherboard Replacement
Cosa ti serve
  1. IQ America VD-8810L Motherboard Replacement, Motherboard: passo 1, immagine 1 di 3 IQ America VD-8810L Motherboard Replacement, Motherboard: passo 1, immagine 2 di 3 IQ America VD-8810L Motherboard Replacement, Motherboard: passo 1, immagine 3 di 3
    • Wedge the spudger into the slot of the panel on the bottom of the device.
    • Rotate out the panel to reveal the screw holding the device together.
  2. IQ America VD-8810L Motherboard Replacement: passo 2, immagine 1 di 2 IQ America VD-8810L Motherboard Replacement: passo 2, immagine 2 di 2
    • Use the Phillips head screwdriver to remove the screw.
    • Separate the Top and bottom halves of the device.
  3. IQ America VD-8810L Motherboard Replacement: passo 3, immagine 1 di 3 IQ America VD-8810L Motherboard Replacement: passo 3, immagine 2 di 3 IQ America VD-8810L Motherboard Replacement: passo 3, immagine 3 di 3
    • Remove batteries from the battery slot.
    • Unscrew the two Phillips head screws in the center of the battery slot.
    • Unscrew the remaining two screws at the bottom of the unit using the 3.0 triangle head screwdriver.
  4. IQ America VD-8810L Motherboard Replacement: passo 4, immagine 1 di 1
    • Use the spudger to separate the top and bottom halves of the screen.
  5. IQ America VD-8810L Motherboard Replacement: passo 5, immagine 1 di 1
    • Disconnect the wires from the green motherboard to the bottom half by pulling apart the connecting pins.
  6. IQ America VD-8810L Motherboard Replacement: passo 6, immagine 1 di 3 IQ America VD-8810L Motherboard Replacement: passo 6, immagine 2 di 3 IQ America VD-8810L Motherboard Replacement: passo 6, immagine 3 di 3
    • Unscrew all 3 Phillips head screws on the outside edges of the motherboard.
  7. IQ America VD-8810L Motherboard Replacement: passo 7, immagine 1 di 1
    • Carefully remove the microphone from the casing by pulling away from the device.
  8. IQ America VD-8810L Motherboard Replacement: passo 8, immagine 1 di 2 IQ America VD-8810L Motherboard Replacement: passo 8, immagine 2 di 2
    • Gently lift the motherboard from the casing to reveal the speaker.
    • Unscrew the two Phillips head screws that hold the speaker in place.
  9. IQ America VD-8810L Motherboard Replacement: passo 9, immagine 1 di 1
    • Refer to this guide to desolder the speaker from the motherboard.
Conclusione
Jackey Lau
Membro da: 10/17/17
301 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 252
