Salta al contenuto principale
HyperX Alloy Origins Toggle Indicator Tab Replacement
Cosa ti serve
  1. HyperX Alloy Origins Toggle Indicator Tab Replacement, Toggle Indicator Tab: passo 1, immagine 1 di 1
    • Locate the toggle indicator tab on the top right corner of the keyboard.
  2. HyperX Alloy Origins Toggle Indicator Tab Replacement: passo 2, immagine 1 di 2 HyperX Alloy Origins Toggle Indicator Tab Replacement: passo 2, immagine 2 di 2
    • Insert the metal spudger or some other separating instrument into the right crevasse between the tab and the keyboard.
    • Lift up gently on the tab, while holding the left side of the tab down.
    • The tab can spring upwards upon removal. Eye protection is recommended during this step.
Conclusione
Adam Sles
Membro da: 10/25/22
310 Reputazione
2 Guide realizzate
UMass Dartmouth, Team 5-2, Sinclaire Fall 2022 Membro di UMass Dartmouth, Team 5-2, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S5G2
5 Membri
15 Guide realizzate
1Commento della guida
Hello! Do I have to forcefully press down the tab? If it starts to bend, should I continue to hold it?
Lorkhall - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 27
Tutti i Tempi: 746
