Introduzione
This guide will show how to replace the frontplate from your HyperX Alloy Origins mechanical keyboard (serial number HX-KB6RDX and its variants).
This task will involve the use of a spudger, Phillips #00 screwdriver, and a soldering workstation. This replacement should be done extremely carefully to avoid injury from the soldering iron. Replacement of the front plate may be required from an accidental spill or broken keys.
Before replacement of the front plate make sure you review and apply the actions in the troubleshooting guide to ensure that your keyboard is not functioning properly.
Cosa ti serve
Locate the toggle indicator tab on the top right corner of the keyboard.
Identify the key switch to be replaced.
Remove its keycap by carefully prying it off of the keyboard with your fingers.
Attrezzo utilizzato in questo passaggio:Desoldering Pump$3.99
Melt the solder surrounding the four pins of the switch's LED, and the two lower pins of the switch body.
To remove the melted solder, use a desoldering iron, a desoldering pump, or desoldering braid.
To reassemble your device, follow these instructions in reverse order. Note that when reattaching the switches back onto the keyboard PCB, the switches need to be held in place behind the keyboard while soldering.
