Salta al contenuto principale
How to repair a broken label loop
Cosa ti serve
  1. How to repair a broken label loop, Locate the defect: passo 1, immagine 1 di 3 How to repair a broken label loop, Locate the defect: passo 1, immagine 2 di 3 How to repair a broken label loop, Locate the defect: passo 1, immagine 3 di 3
    • Locate the broken tag, and find the area where it snapped off from
  2. How to repair a broken label loop, Tidy the broken area: passo 2, immagine 1 di 3 How to repair a broken label loop, Tidy the broken area: passo 2, immagine 2 di 3 How to repair a broken label loop, Tidy the broken area: passo 2, immagine 3 di 3
    • Often the cause of the breakage, is that the sewing thread tore through the tag, leaving frayed ends
    • Trim away any damaged or frayed ends of the tag
    • Use a "seam ripper" tool, or small scissors, to carefully remove the old thread from the item
  3. How to repair a broken label loop, Re-attach the label: passo 3, immagine 1 di 3 How to repair a broken label loop, Re-attach the label: passo 3, immagine 2 di 3 How to repair a broken label loop, Re-attach the label: passo 3, immagine 3 di 3
    • Prepare your sewing machine in a clean location, and position the item underneath the needle. Depress the foot to secure the item in place.
    • Tip: for setting up a sewing machine, use the resource Thread a Sewing Machine
    • Make a short lock stitch, and then a straight line stitch from one side of the label to the other. Make a second stitch using the reverse lever, and one final stitch in the original direction. Finish with a locking stitch
    • Remove the item from the machine.
  4. How to repair a broken label loop, Trim the repair: passo 4, immagine 1 di 3 How to repair a broken label loop, Trim the repair: passo 4, immagine 2 di 3 How to repair a broken label loop, Trim the repair: passo 4, immagine 3 di 3
    • Carefully trim the thread on the outside...
    • ... and on the inside
    • Check the repair and pull the label gently to test the durability
  5. How to repair a broken label loop, Finished and ready!: passo 5, immagine 1 di 1
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Conclusione
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Ben Blischke
Membro da: 07/19/23
10.230 Reputazione
66 Guide realizzate
INTERSPORT Membro di INTERSPORT
Community
25 Membri
169 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 31
Tutti i Tempi: 341
