Salta al contenuto principale
How to Replace the Back Cover Adhesive (Frame First)
Cosa ti serve
  1. How to Replace the Back Cover Adhesive (Frame First), Remove the remaining adhesive: passo 1, immagine 1 di 1
    • If you're re-using your frame, remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat and isopropyl alcohol (90% or greater) if you're having trouble removing the adhesive.
    • Repeat the same procedure for any remaining adhesive on the back cover.
  2. How to Replace the Back Cover Adhesive (Frame First): passo 2, immagine 1 di 1
    • Before removing any liners, position the adhesive strip with the clear liner facing down over the frame to find the proper orientation.
    • You can use the rear camera cutout as a reference point.
    • If the adhesive matches the back cover instead of the frame, follow this cover-first adhesive guide.
  3. How to Replace the Back Cover Adhesive (Frame First), Expose the adhesive: passo 3, immagine 1 di 2 How to Replace the Back Cover Adhesive (Frame First), Expose the adhesive: passo 3, immagine 2 di 2
    • Peel the clear liner off of the adhesive strip to expose the adhesive.
  4. How to Replace the Back Cover Adhesive (Frame First), Align the adhesive: passo 4, immagine 1 di 3 How to Replace the Back Cover Adhesive (Frame First), Align the adhesive: passo 4, immagine 2 di 3 How to Replace the Back Cover Adhesive (Frame First), Align the adhesive: passo 4, immagine 3 di 3
    • Be very careful with this step, as misaligning the adhesive can cause it to peek out of the phone during reassembly, leading to an improper seal.
    • The adhesive is very sticky! Be careful with alignment, as you won't be able to reposition the adhesive once it sticks.
    • Carefully align the sticky side of the adhesive over the edges of the frame.
    • You can use the screw holes to help line up the adhesive.
    • Press down on the perimeter of the adhesive strip to bond it to the frame.
  5. How to Replace the Back Cover Adhesive (Frame First): passo 5, immagine 1 di 2 How to Replace the Back Cover Adhesive (Frame First): passo 5, immagine 2 di 2
    • Peel off the colored liner from the adhesive strip to expose the opposite side of the adhesive.
  6. How to Replace the Back Cover Adhesive (Frame First): passo 6, immagine 1 di 2 How to Replace the Back Cover Adhesive (Frame First): passo 6, immagine 2 di 2
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Align the back cover with its original position on the frame.
    • Press down on the perimeter of the adhesive to bond the adhesive to the back cover.
    • To ensure a good seal, apply constant pressure to the back cover with a flat, heavy object. A hefty book works well.
    • If a substantial gap remains, try squeezing the gap with your fingers but don't force it. Pry the back cover off and check for any surface irregularities, such as unseated connectors or loose and jutting screws.
Linea Traguardo
Altre 17 persone hanno completato questa guida.
Alex Diaz-Kokaisl
Membro da: 01/16/22
213.566 Reputazione
1.040 Guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
23.649 Guide realizzate
2Commenti sulla guida
Many thanks for the instructions.
Note:
Unfortunately, removing the old adhesive is a laborious process that requires a lot of effort. (Samsung Note 20 Ultra 5G with adhesive film that has already completely dissolved on its own!)
Absolutely necessary - in addition to patience: ISOPROPANOL (e.g. https://amzn.eu/d/7ZIPJCJ) - this dissolves all adhesives (be careful)!
Carefully scrape off the adhesive layers with a plastic spatula - plus cotton swabs plus cosmetic tissues (do not leave lint) then laboriously remove the adhesive residue.
ISOPROPANOL 99.9% does not damage electronics, i.e. can therefore be used for cleaning without hesitation.
Woody Woodpecker - Replica
Unfortunately, though your repair instructions have separate links for a preglued template or glue tape, the links both lead to the template instructions. There is nothing on glue tape for sealing your phone. Could you please add instructions?
Joan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 39
Ultimi 7 Giorni: 166
Ultimi 30 Giorni: 824
Tutti i Tempi: 17,793
