Salta al contenuto principale
How to Replace a Speaker on a Yamaha PSS-130 Keyboard
Cosa ti serve
  1. How to Replace a Speaker on a Yamaha PSS-130 Keyboard, Internal Speaker: passo 1, immagine 1 di 2 How to Replace a Speaker on a Yamaha PSS-130 Keyboard, Internal Speaker: passo 1, immagine 2 di 2
    • Remove the battery cover.
    • Remove all twelve of the 9.0 mm screws on the back cover of the device's casing using a Phillips #1 screwdriver.
  2. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: passo 2, immagine 1 di 3 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: passo 2, immagine 2 di 3 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: passo 2, immagine 3 di 3
    • Place your fingers in the battery compartment, and place your thumb on the back of the keyboard.
    • Grip inside battery cover and push on the back of the keyboard with your thumb.
  3. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: passo 3, immagine 1 di 2 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: passo 3, immagine 2 di 2
    • Replace two 9.0 mm Phillips screws to keep the keys from falling out while working on this device.
  4. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: passo 4, immagine 1 di 3 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: passo 4, immagine 2 di 3 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: passo 4, immagine 3 di 3
    • Rotate the keyboard to get a better angle with the soldering iron.
  5. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: passo 5, immagine 1 di 1
    • Desolder the connections of the old speaker using the soldering iron and the solder wick.
  6. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: passo 6, immagine 1 di 3 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: passo 6, immagine 2 di 3 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: passo 6, immagine 3 di 3
    • Remove the fasteners using an 11 mm socket wrench.
    • It will take very little torque to strip the plastic, so make sure that your wrench is turning them to the left.
  7. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: passo 7, immagine 1 di 2 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: passo 7, immagine 2 di 2
    • The speaker should now be free. Simply lift the speaker out.
    • Using the same process, place the new speaker in the speaker indentation.
    • My own speaker was not malfunctioning so I did not replace it.
  8. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: passo 8, immagine 1 di 1
    • Replace the fasteners that were removed in step 6, this time tightening to the right.
  9. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: passo 9, immagine 1 di 1
    • Solder the new speaker to the wires taken off in step 5.
Conclusione
To reassemble your device, follow these instructions in reverse order from step 3.
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 608
