Introduzione
Use this guide to remove the top panel in your LG front load washing machine.
Removing the top panel gives you access to many of the washer's internal components, such as the detergent dispenser, main control board, air dome, etc.
This guide will work for most LG front load washing machines. This guide is written with a model WM3050CW washer. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
Cosa ti serve
Turn off the main water supply
Unplug your washer
Disconnect all water connections at the rear of your washer
Remove the screw(s) securing the top panel brackets to the back panel.
Slide the top panel towards the rear of the device to disconnect its clips.
Repair didn’t go as planned? Ask our Answers community for help.
