Salta al contenuto principale
How to Open the Rotor Riot
Cosa ti serve
  1. How to Open the Rotor Riot, Remove the iPhone mount: passo 1, immagine 1 di 3 How to Open the Rotor Riot, Remove the iPhone mount: passo 1, immagine 2 di 3 How to Open the Rotor Riot, Remove the iPhone mount: passo 1, immagine 3 di 3
    • Use your fingers to remove the screw on the back side of the controller securing the iPhone mount.
    • Remove the iPhone mount.
  2. How to Open the Rotor Riot, Unscrew the back cover: passo 2, immagine 1 di 1
    • Use a T6 Torx screwdriver to remove the eight 9.2 mm-long screws securing the back cover.
    • Don't try to remove the back cover all the way yet! It's still connected to the mainboard.
  3. How to Open the Rotor Riot, Swing open the back cover: passo 3, immagine 1 di 3 How to Open the Rotor Riot, Swing open the back cover: passo 3, immagine 2 di 3 How to Open the Rotor Riot, Swing open the back cover: passo 3, immagine 3 di 3
    • Lift up the back cover of the controller.
    • Lift the back cover to a 45 degree angle and place it next to the controller.
    • Don't strain the interconnect cable during this procedure.
  4. How to Open the Rotor Riot, Disconnect the phone connector cable: passo 4, immagine 1 di 3 How to Open the Rotor Riot, Disconnect the phone connector cable: passo 4, immagine 2 di 3 How to Open the Rotor Riot, Disconnect the phone connector cable: passo 4, immagine 3 di 3
    • Use a spudger to disconnect the phone connector cable from the mainboard.
  5. How to Open the Rotor Riot, Remove the back cover: passo 5, immagine 1 di 1
    • Remove the back cover.
Conclusione
Adriana Zwink
Membro da: 12/18/19
62.495 Reputazione
167 Guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
23.755 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 396
