Introduzione
This guide shows how to install a plastic snap (aka snap fastener, snap button, or press button) using a handheld fastener tool.
Plastic snaps are versatile fasteners that are great for clothing, bags, device covers, bedding, etc. Compared to metal snaps, plastic snap tools are reasonably affordable, and the snap components are very cheap. You can also get plastic snaps in a variety of colors and sizes.
If you're replacing a broken snap, check out this guide.
If you're installing metal snaps, follow this guide instead.
Cosa ti serve
Push the point of an awl through the fabric to pierce a hole for the snap.
Visually inspect the snap. The center pin should be evenly flattened.
Pull on the snap. The snap shouldn't feel loose.
If the pin isn't evenly flattened or the snap feels loose, use the fastener tool to compress the snap again. If that doesn't fix it, remove the snap and start again.
Repeat the procedure to install the other half of the snap set.
For more clothing repair guides, click here.
Altre 2 persone hanno completato questa guida.
