Salta al contenuto principale
How to Exit ZTE Max XL Field Test Mode
  1. How to Exit ZTE Max XL Field Test Mode, How to Exit ZTE Max XL Field Test Mode: passo 1, immagine 1 di 1
    • Field Test Mode (FTM) can be useful if you perform tests on signal strength, but for most users it prevents some applications to run correctly.
    • The phone screen will display FTM when in the mode.
  2. How to Exit ZTE Max XL Field Test Mode: passo 2, immagine 1 di 1
    • Hold down the power button for 10 seconds to turn off the phone.
  3. How to Exit ZTE Max XL Field Test Mode: passo 3, immagine 1 di 1
    • Press the power button until your phone responds to power on the phone.
    • To assure your phone does not stay in FTM, DO NOT press the lower volume button. Pressing of the lower volume button is the reason your phone enters FTM.
  4. How to Exit ZTE Max XL Field Test Mode: passo 4, immagine 1 di 2 How to Exit ZTE Max XL Field Test Mode: passo 4, immagine 2 di 2
    • If the phone is still in FTM after the reboot, make sure the lower volume button is not stuck.
    • After the button is unstuck, repeat step three.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
Olivia Wolf
Membro da: 02/15/18
1.400 Reputazione
5 Guide realizzate
UW Stout, Team S8-G2, Ogden Spring 2018 Membro di UW Stout, Team S8-G2, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G2
4 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 15
Tutti i Tempi: 846
