Salta al contenuto principale
How to Clean the Ports on your Electronic Device
Cosa ti serve
  1. How to Clean the Ports on your Electronic Device, Inspect your ports: passo 1, immagine 1 di 3 How to Clean the Ports on your Electronic Device, Inspect your ports: passo 1, immagine 2 di 3 How to Clean the Ports on your Electronic Device, Inspect your ports: passo 1, immagine 3 di 3
  2. How to Clean the Ports on your Electronic Device, Blow air into the USB-C port: passo 2, immagine 1 di 2 How to Clean the Ports on your Electronic Device, Blow air into the USB-C port: passo 2, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Dust Blower
    $5.99
    • Don't use your mouth to blow into your USB-C port, as the moisture from your breath can damage the contacts.
    • Insert the tip of a dust blower, or the nozzle of compressed air, at one corner of the port.
    • This gives room for any debris to eject out of the port.
    • Blow a few puffs of air into the port.
    • Plug in your device to check if it works and if the connector is fully seated.
    • If your device isn't working or seats properly, unplug it and repeat the blowing process.
    • If your device still doesn't work or sits properly after multiple repetitions, move to the next step.
  3. How to Clean the Ports on your Electronic Device, Brush your USB-C port: passo 3, immagine 1 di 3 How to Clean the Ports on your Electronic Device, Brush your USB-C port: passo 3, immagine 2 di 3 How to Clean the Ports on your Electronic Device, Brush your USB-C port: passo 3, immagine 3 di 3
    • Don't use any metal tools to clean the USB-C port, as you risk damaging it.
    • Insert the head of a brush, like a dry toothbrush, into the port, making sure the hairs surround the middle contact pad (the black tab in the middle of the port).
    • Gently turn the brush in small circles to break up any clumped debris.
    • Remove the brush and use a dust blower or compressed air to blow out any debris.
    • If any debris is stuck, reinsert the brush and rotate it to let the hairs "scoop" out any debris.
    • Plug in your device and check if it's working. If it's still not working, move on to the next step.
  4. How to Clean the Ports on your Electronic Device, Clean the port with isopropyl alcohol: passo 4, immagine 1 di 3 How to Clean the Ports on your Electronic Device, Clean the port with isopropyl alcohol: passo 4, immagine 2 di 3 How to Clean the Ports on your Electronic Device, Clean the port with isopropyl alcohol: passo 4, immagine 3 di 3
    • Follow this guide to make a custom cotton swab.
    • You can also use dental picks with barbed tips (non-flavored).
    • You can use a normal cotton swab, but most are too thick and have loose cotton that can snag on sharp edges.
    • Apply a few drops of highly-concentrated isopropyl alcohol (>90%) to the cotton.
    • Insert your tool between the middle contact pad and the perimeter of the USB-C port itself.
    • Don't force the tool into the port, as you risk breaking the middle contact pad.
    • Slide the tool along the perimeter of the port to clean it.
    • Wait a few minutes for the isopropyl alcohol to evaporate before plugging in your device and testing it.
  5. How to Clean the Ports on your Electronic Device, Blow air into the audio port: passo 5, immagine 1 di 2 How to Clean the Ports on your Electronic Device, Blow air into the audio port: passo 5, immagine 2 di 2
    • Don't use your mouth to blow into your audio port, as the moisture from your breath can damage the contacts.
    • Insert the tip of a dust blower, or the nozzle of compressed air, at one end of the port.
  6. How to Clean the Ports on your Electronic Device, Brush your audio port: passo 6, immagine 1 di 3 How to Clean the Ports on your Electronic Device, Brush your audio port: passo 6, immagine 2 di 3 How to Clean the Ports on your Electronic Device, Brush your audio port: passo 6, immagine 3 di 3
    • Don't use any metal tools to clean the audio port, as you risk damaging it.
    • Insert the head of a brush, like a dry toothbrush, into the audio port.
  7. How to Clean the Ports on your Electronic Device, Clean the audio port with isopropyl alcohol: passo 7, immagine 1 di 3 How to Clean the Ports on your Electronic Device, Clean the audio port with isopropyl alcohol: passo 7, immagine 2 di 3 How to Clean the Ports on your Electronic Device, Clean the audio port with isopropyl alcohol: passo 7, immagine 3 di 3
    • Insert your tool in the audio port.
    • Don't force the tool into the port, as you risk damaging the contacts.
    • Twist the tool back and forth within the port to clean it.
  8. How to Clean the Ports on your Electronic Device, Blow air into the USB-A port: passo 8, immagine 1 di 2 How to Clean the Ports on your Electronic Device, Blow air into the USB-A port: passo 8, immagine 2 di 2
    • Don't use your mouth to blow into your USB-A port, as the moisture from your breath can damage the contacts.
  9. How to Clean the Ports on your Electronic Device, Brush your USB-A port: passo 9, immagine 1 di 3 How to Clean the Ports on your Electronic Device, Brush your USB-A port: passo 9, immagine 2 di 3 How to Clean the Ports on your Electronic Device, Brush your USB-A port: passo 9, immagine 3 di 3
    • Don't use any metal tools to clean the USB-A port, as you risk damaging it.
    • Insert the head of a brush, like a dry toothbrush, into the port.
    • Gently slide the brush back and forth to break up any clumped debris.
  10. How to Clean the Ports on your Electronic Device, Clean the USB-A port with isopropyl alcohol: passo 10, immagine 1 di 3 How to Clean the Ports on your Electronic Device, Clean the USB-A port with isopropyl alcohol: passo 10, immagine 2 di 3 How to Clean the Ports on your Electronic Device, Clean the USB-A port with isopropyl alcohol: passo 10, immagine 3 di 3
    • Insert your tool in the USB-A port.
    • Don't force the tool into the port, as you risk damaging the contacts and getting the tool stuck.
    • Slide the tool back and forth along the port to clean it.
  11. How to Clean the Ports on your Electronic Device, Blow air into the HDMI port: passo 11, immagine 1 di 2 How to Clean the Ports on your Electronic Device, Blow air into the HDMI port: passo 11, immagine 2 di 2
    • Don't use your mouth to blow into your HDMI port, as the moisture from your breath can damage the contacts.
  12. How to Clean the Ports on your Electronic Device, Brush your HDMI port: passo 12, immagine 1 di 2 How to Clean the Ports on your Electronic Device, Brush your HDMI port: passo 12, immagine 2 di 2
    • Don't use any metal tools to clean the HDMI port, as you risk damaging it.
    • Insert the head of a brush, like a dry toothbrush, into the port, making sure the hairs surround the middle contact pad (the black tab in the middle of the HDMI port).
  13. How to Clean the Ports on your Electronic Device, Clean the HDMI port with isopropyl alcohol: passo 13, immagine 1 di 3 How to Clean the Ports on your Electronic Device, Clean the HDMI port with isopropyl alcohol: passo 13, immagine 2 di 3 How to Clean the Ports on your Electronic Device, Clean the HDMI port with isopropyl alcohol: passo 13, immagine 3 di 3
    • Insert your tool between the middle contact pad and the perimeter of the HDMI port itself.
  14. How to Clean the Ports on your Electronic Device, Blow air into the charging port: passo 14, immagine 1 di 2 How to Clean the Ports on your Electronic Device, Blow air into the charging port: passo 14, immagine 2 di 2
    • Don't use your mouth to blow into your charging port, as the moisture from your breath can damage the contacts.
  15. How to Clean the Ports on your Electronic Device, Brush your charging port: passo 15, immagine 1 di 2 How to Clean the Ports on your Electronic Device, Brush your charging port: passo 15, immagine 2 di 2
    • Don't use any metal tools to clean the charging port, as you risk damaging it.
    • Insert the head of a brush, like a dry toothbrush, into the charging port.
  16. How to Clean the Ports on your Electronic Device, Clean the charging port with isopropyl alcohol: passo 16, immagine 1 di 3 How to Clean the Ports on your Electronic Device, Clean the charging port with isopropyl alcohol: passo 16, immagine 2 di 3 How to Clean the Ports on your Electronic Device, Clean the charging port with isopropyl alcohol: passo 16, immagine 3 di 3
    • Insert your tool in the charging port.
    • Don't force the tool in and out of the port, as you risk damaging the contacts or getting cotton wedged in the port.
    • Rotate the tool around the perimeter of the port to clean it.
Conclusione
For other general electronics skills guides, click here.
Altre 6 persone hanno completato questa guida.
Alex Diaz-Kokaisl
Membro da: 01/16/22
214.551 Reputazione
1.044 Guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
23.765 Guide realizzate
2Commenti sulla guida
This comes at a time where my Galaxy S9 thinks the port is broken so often I've changed to my old phone and gotten a wireless charger. Might as well give it a proper deep clean some day.
FarmYard Gaming - Replica
There isn't much evidence to support that cleaning ports like this is going to make any real difference. Ports get dirty due to abuse. Ports fail because of abuse. Cleaning an abused port isn't the fix. A single drop of light machine oil, wd40, sewing machine oil, or paraffin oil is all that is required to service connection ports. Unless there is half a cream cheese bagel jammed inside a usb port, this guide is rubbish.
Jade - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 136
Ultimi 7 Giorni: 844
Ultimi 30 Giorni: 4,225
Tutti i Tempi: 42,305
