Introduzione
This is for the inline 4 cylinder, the V6 will be different. The first thing you need to do is remove the cylinder head cover. You can refer to our head cover gasket removal video. The crankshaft turns 180 degree clockwise (camshaft pulley turns 90 degree). You will have to turn the crank pulley when adjusting the valve clearance on each cylinder.
Torque specs:
- 14 ft. lbs - Intake locknut
- 10 ft. lbs - Exhaust locknut
Valve lash specs:
- 0.21-0.25 mm (0.008-0.010 in) - Intake
- 0.28-0.32 mm (0.011-0.013 in) - Exhaust
Safety
If this is your first time working on a vehicle read our safety tips before proceeding.
Strumenti
Ricambi
Nessuna parte specificata.
Istruzioni Video
0 Commenti
