Salta al contenuto principale
How Install a Mac SSD into an OWC Envoy Pro Enclosure
Cosa ti serve
  1. How Install a Mac SSD into an OWC Envoy Pro Enclosure, How Install a Mac SSD into an OWC Envoy Pro Enclosure: passo 1, immagine 1 di 3 How Install a Mac SSD into an OWC Envoy Pro Enclosure, How Install a Mac SSD into an OWC Envoy Pro Enclosure: passo 1, immagine 2 di 3 How Install a Mac SSD into an OWC Envoy Pro Enclosure, How Install a Mac SSD into an OWC Envoy Pro Enclosure: passo 1, immagine 3 di 3
    • To open the enclosure, pull the top half down toward the wedged end and lift it away from the bottom half.
  2. How Install a Mac SSD into an OWC Envoy Pro Enclosure: passo 2, immagine 1 di 3 How Install a Mac SSD into an OWC Envoy Pro Enclosure: passo 2, immagine 2 di 3 How Install a Mac SSD into an OWC Envoy Pro Enclosure: passo 2, immagine 3 di 3
    • Carefully insert your Mac OEM SSD as shown at left, with the golden contact pads below the connector pins facing upward.
    • The SSD might take a significant amount of force to insert. Make sure you have the orientation correct before you apply any pressure.
    • When the SSD is fully inserted, you should barely be able to see the golden contact points at the top of the drive, and the notch at the bottom of the drive should be aligned with the hole for the screw in the enclosure.
  3. How Install a Mac SSD into an OWC Envoy Pro Enclosure: passo 3, immagine 1 di 1
    • Use a T5 Torx driver to install the 6.5 mm screw securing the bottom of the SSD.
  4. How Install a Mac SSD into an OWC Envoy Pro Enclosure: passo 4, immagine 1 di 3 How Install a Mac SSD into an OWC Envoy Pro Enclosure: passo 4, immagine 2 di 3 How Install a Mac SSD into an OWC Envoy Pro Enclosure: passo 4, immagine 3 di 3
    • Reinstall the top half of the enclosure and slide it closed.
  5. How Install a Mac SSD into an OWC Envoy Pro Enclosure: passo 5, immagine 1 di 1
    • Use a T5 Torx driver to install the two 7.6 mm screws on the bottom of the enclosure.
  6. How Install a Mac SSD into an OWC Envoy Pro Enclosure: passo 6, immagine 1 di 3 How Install a Mac SSD into an OWC Envoy Pro Enclosure: passo 6, immagine 2 di 3 How Install a Mac SSD into an OWC Envoy Pro Enclosure: passo 6, immagine 3 di 3
    • Remove the backing from the adhesive on the extra rubber foot provided in the plastic bag with the screws.
    • With the backing removed, place the sticky side of the rubber foot down over the screws you just inserted, and apply pressure to it for 30 seconds.
  7. How Install a Mac SSD into an OWC Envoy Pro Enclosure: passo 7, immagine 1 di 1
    • The drive is now ready to be connected to your computer with the included USB cable.
Conclusione
Once your drive is installed, you can transfer data from it, or use Disk Utility to format it and use it as a Time Machine backup.
Altre 15 persone hanno completato questa guida.
Taylor Dixon
Membro da: 06/26/18
67.116 Reputazione
94 Guide realizzate
7 Commenti
Does anyone know why the OWC Envoy Pro enclosure DOES NOT work with the OWC’s Aura Pro drive? I have noticed the warning (included above as well) that the enclosure only works with “factory-installed Mac Solid State Drives”. One would think that if the OWC Aura Pro drive can serve as a replacement for a Mac SSD that it should work in the Envoy Pro enclosure as well. The reason that I ask is that it would be much easier to format and transfer data to the Aura Pro drive via the enclosure rather than having to do this all after installation in the Mac computer.
markbrandon - Replica
I have OWC 480Gb SSD for MacBookAir mid 2012. I called OWC to ask the same question. I was told that it actually was a Heat matter, that it would work but at my own risk. I feel I was lucky to get that response and that they probably do not give it any more. I tried it with success, keeping the Enclosure lid open. I would not use it extensively though. For extra safety you can always use a small fan to cool it up. I think you can respect their recommandations by booting from the external enclosure with the original Mac SSD in it and then Clone it to the internal freshly formatted OWC SSD. I now have another OWC 480Gb SSD for MacBookAir 2015. Am I going to have the guts to also give it a try ? Just to play safe I will try not to. So I would suggest that a Heat Monitoring Program be installed and that both Original Apple and OWC SSD Temperature be monitored and compared.
Michel - Replica
12312312312312312
vasiliy -
I have one of these, and the SSD has gone bad. (Once connected, it randomly and quickly disconnects and reconnects.) So I'm planning on removing and trashing/destroying the old SSD. But then I have a perfectly good enclosure. Is this ONLY for MacBook SSDs, or are there other SSDs (etc) that would work with it to provide another external drive?
Mark Wilson - Replica
Hallo IFIXIT Team, ich hätte eine Frage. Ich habe eine original ssd aus einem MacBook Pro 2017 ausgebaut und möchte diesen in ein ext. Festplatten Gehäuse einbauen. Ich finde aber leider keine passendes Gehäuse das diese ssd lesen kann. Gibt es ein passendes ext. Gehäuse dafür?
Weniger anzeigen
Bülent - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 75
Ultimi 30 Giorni: 414
Tutti i Tempi: 19,880
